Date/Time: Sun, 24 Nov 2024 23:17:07 +0000
Link Bar Period Value and Length of an indicator to symbol in qu
View Count: 159
[2024-04-16 16:07:01] |
User757816 - Posts: 17 |
Hello, I watch 12 instruments on a quote board. I need to change bar period value (volume bar) and length of Chaikin Money Flow in 3 charts for each instruments. How can I do? Thank you
[2024-04-16 16:10:45] |
The only way to make this happen automatically would be to create a custom study. Refer to the following: sc.SetChartStudyInputFloat() You could also save multiple Study Collections, so you would just need to select the correct Study Collection after changing the symbol. Refer to the following: Study Collections Otherwise, you would need to have multiple charts (or use multiple chartbooks) to track the different symbols and have the charts setup the way you want. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
