Date/Time: Sun, 24 Nov 2024 23:39:52 +0000
IMPORTANT! An update seems to be required for TPO Profile Chart study
View Count: 225
[2024-04-16 10:12:29] |
User293951 - Posts: 15 |
I have tried a lot to display the proper values but there seems to be a necessity for update. I am using the classic TPO chart (Market Profile), with opening and closing ranges both at the same time. I am studying the equities market (NQ and ES contracts). If no 'overnight' session is used and only RTH profile is displayed, then everything seems to be working fine. The problem arises when I use both ETH and RTH profiles separately (F5->Session Start Time:9:30, Session End Time:15:59:59, Use Evening Session:Yes, Evening Start Time:16:00, Evening End Time:9:29:59). Normally I ommit the ETH profile for all days excluding the current session. So in my chart I have only the RTH profile of the previous sessions and both ETH and RTH profiles for the current session. In this case, for all previous RTH profiles, the closing range is displayed wrong, taking into consideration the closing range of the previous ETH profile and not the previous RTH profile. When I switch to only RTH sessions (F5->Session Start Time:9:30, Session End Time:15:59:59, Use Evening Session:No), then the closing range of all previous profiles (RTH only) is correctly displayed. So, an update is required so as to be able to display the closing range of only RTH profiles when the option 'Exclude Evening Session Profiles Except for Last Day' is enabled. Otherwise, the closing range of previous RTH profiles is displayed wrong and refers to the closing range of the corresponding previous ETH profile. |
[2024-04-16 14:29:47] |
Sierra_Chart Engineering - Posts: 17163 |
Yes this is correct: So, an update is required so as to be able to display the closing range of only RTH profiles when the option 'Exclude Evening Session Profiles Except for Last Day' is enabled.
The documentation does say this: Time Price Opportunity (TPO) Profile Charts: Exclude Evening Session Profiles Except For Last Day Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-17 14:32:47] |
Are there any chances of having any update any time in the foreseeable future? Thanks.
