Date/Time: Wed, 27 Nov 2024 06:29:30 +0000
Downloading OHLCV and indicators to spreadsheets
View Count: 1144
[2014-08-14 14:35:25]
User27542 - Posts: 20
I'm new to Sierra Chart, and would like to know how I can download price and volume data, and, if possible, indicator values directly to spreadsheet. With thanks for any help you can give, and documentation or examples you can direct me to.
[2014-08-14 14:58:43]
User021827 - Posts: 174
When you add a spreadseet study for trading, that info is loaded to the spreadsheet .
Any indicator you have on the chart will also have it's values loaded to the spreadsheet.
Load a spreadsheet study for trading , then have a look at the spreadsheet and you see all this info.
regards
[2014-08-14 15:11:09]
Many thanks. I hadn't realised that this was done within Studies. Regards.
[2014-08-14 15:38:21]
there is also spreadsheet study for alerts which you can use to create alerts with the data and indicators.
either one will give you all the data.
[2014-08-14 15:58:49]
Sawtooth - Posts: 4120
All three spreadsheet studies output OHLCVT and indicator data.
[2014-08-14 16:03:32]
OK, great. Thanks for letting me know.
[2014-08-14 17:32:46]
You will need to use a Spreadsheet study. Refer to the documentation here for this:
https://www.sierrachart.com/index.php?page=doc/doc_SpreadsheetStudy.html
