Date/Time: Sun, 24 Nov 2024 23:37:35 +0000
STRING TOP OF THE WINDOW
View Count: 187
[2024-04-16 07:21:21]
User993113 - Posts: 73
Is there a way to modify or remove/hide the first string at the top of the window?
Sierra Chart n. version, routing, date ...etc
image4ec0138368c672c7296476d0868d2cc6.png / V - Attached On 2024-04-16 07:17:07 UTC - Size: 3.2 KB - 58 views
[2024-04-16 14:59:56]
There is not a way to change the information displayed in the Title Bar.
The one thing that can be done related to this, is to change the "Title Bar Name" for each chart, so you can then see this particular item in the Title Bar. Refer to the following:
Chart Settings: Title Bar Name (Chart >> Chart Settings >> Display >> Chart Display Items menu)
Also note the setting just below the link given above for "Use Title Bar Name as Tab Label", as this may be something else you would be interested in.
