Date/Time: Sun, 24 Nov 2024 23:03:53 +0000
order fill markers drawn out of sync
View Count: 321
[2024-04-15 20:12:59] |
jivetrader - Posts: 410 |
Hi, sometimes order fills are drawn several bars to the right vs on the bar at which they were executed. How can I correct this?
trade markers off.png / V - Attached On 2024-04-15 20:11:28 UTC - Size: 4.35 KB - 65 views |
[2024-04-15 20:32:41] |
Refer to the following: Chart Trading and the Chart DOM: Misaligned Order Fill Markers on Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-17 18:21:24] |
I have followed the procedures for checking computer date & time, checking the trade symbol, delete & redownload data, etc. and it has not helped. The misalignment only started happening recently. It is difficult to gauge trading performance with this problem. Can you provide more advice please. Note that fills seem to be shown approx. 1min late on the charts. Actually it's hard to tell, but it's a small amount. All charts in my chartbook reflect the same problem. thanks Date Time Of Last Edit: 2024-04-17 19:13:52
[2024-04-18 17:35:29] |
Sierra_Chart Engineering - Posts: 17163 |
Are the timestamps of the fills incorrect? Look at the Trade Activity Log for those fills and check the Transaction Date-Time: Trade Activity Log: Viewing Historical Trade Activity Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
