Date/Time: Mon, 25 Nov 2024 02:00:00 +0000
DAX for Traiol Period and therafter
View Count: 227
[2024-04-15 17:27:14] |
User643437 - Posts: 2 |
Hi, I wish to sim/trial trade the DAX Future Market with TPO and FootPrint (DOM not nescessary for now). Delayed data feed will surfice for now also Is this possible with Sierra? After trial period, what is the overall cost, ie. Charts and external data feed for Dax? Thanks in advance and Best Regards |
[2024-04-15 17:58:06] |
You do not have access to the DAX as you had not activated the trial for your account. We have gone ahead and activated the trial for your account. So you now have access to all the delayed streaming data we have available. Everything you need is now available to you. After the trial, if you are wanting real-time data (and/or want to connect to a trading service) then you need to be on one of the "Integrated" packages. And since you want Numbers Bars (footprint) and TPO, you would need to be on one of the "Advanced" packages. The lowest cost option is the "Integrated Advanced" package for $46.00 per month. Refer to the information for the packages and their pricing at the following link: Description of Service Packages and Pricing The EUREX data from us costs $25.00 per month. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-15 18:14:53] |
Thank you John, So "Integrated Advanced" package for $46.00 per month and I must add $25 for the Real Time data, ie. $71 in total, right? |
[2024-04-15 20:25:14] |
This is correct. The "Integrated Advanced" package is the lowest priced option for what you are wanting. Note that there are 3 month and 6 month pre-purchase options that give a 10% and 20% discounts (respectively). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
