Date/Time: Mon, 25 Nov 2024 01:53:20 +0000
do not trigger when c between 2 levels
View Count: 191
[2024-04-15 14:36:33] |
Bedhog - Posts: 179 |
Hello. I'm having trouble getting this to work... I don't want this alert to trigger if the current price is between id122.sg1 and id123.sg1. What is the best syntax to use for this? =and( !c<id122.sg1, !c>id123.sg1, other stuff here, ) Thank you. |
[2024-04-15 17:26:59] |
But, to do what you are wanting you would need the following (not knowing anything about these subgraphs): =OR(AND(C > ID22.SG1, C < ID23.SG1), AND(C < ID22.SG1, C > ID23.SG1)) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-04-16 14:13:08
[2024-04-15 21:10:53] |
Thanks John. I was able to solve the problem after reviewing the example by creating a "trigger" that evaluates true when the close is between those 2 levels. id129.sg1 = true =and(c<id122.sg1,c>id123.sg1) Then I was able to use the "!" in the original calculation. =and( !id129.sg1, other stuff here, ) |
