Date/Time: Mon, 25 Nov 2024 02:11:58 +0000
Multi OCO orders - default setting to Points instead of Ticks?
View Count: 177
[2024-04-14 17:22:04] |
User8135477 - Posts: 115 |
Every time I try to set up a new template for multi-target OCO orders, it is displayed in ticks and I have to manually change to points. Is there a way to change the global settings so that it defaults to points and not ticks?
[2024-04-15 16:34:54] |
There is not a way to change the default for the Attached Orders offset type. But what you can do is to recall one of your existing Trade Configurations, which is set in Points and then modify from there. Refer to the following: Basic Trading and the Trade Window: Using and Changing Between Different Trade Window and Attached Orders Configurations For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
