Date/Time: Mon, 25 Nov 2024 00:28:48 +0000
Trial reset
View Count: 237
[2024-04-13 11:00:58]
RubberToe - Posts: 1
Is there a procedure to follow to use the trial again after 6 months? I want to give SC another attempt with third party chartbooks. Thx.
[2024-04-13 17:14:53]
Sierra_Chart Engineering - Posts: 17164
Your account has been activated and the usage time extended if necessary.
If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu.
To get started with Sierra Chart, follow the Sierra Chart setup instructions here:
Sierra Chart Setup Instructions 1
After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit".
