Date/Time: Mon, 25 Nov 2024 01:59:32 +0000
Value label tick offset on Spreadsheet Formula Study
View Count: 209
[2024-04-13 02:04:11] |
User835837 - Posts: 6 |
I wanted to have the bar size display on top of bar with an offset option. this is the formula i used for the study , (H-L)/TICKSIZE and have the draw option to be value on high of each bar, but no ability to have the option to offset the value display in ticks as its too close to the top of each candlestick. |
Screenshot 2024-04-12 at 6.56.01 PM.png / V - Attached On 2024-04-13 02:02:34 UTC - Size: 10.28 KB - 49 views Attachment Deleted. |
[2024-04-15 14:31:01] |
Use the "Study Subgraph Above/Below Bar as Text" study and have it reference the subgraph that you are using right now. This study gives the ability to offset the location of the value. Refer to the following: Study Subgraph Above/Below Bar as Text For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
