Date/Time: Thu, 17 Sep 2026 15:08:06 +0000
Account Name Visibility
View Count: 783
| [2024-04-12 12:38:19] |
| trad - Posts: 52 |
Due to the number of characters, account names are being truncated in the trade window. To address this, I wanted to display the full account name in a larger font directly on the chart. While the name does appear in the left corner, the font size is too small. I've tried looking through the graphics settings, but I couldn't find the option that controls the size of the account name on the chart. Could you please guide me on how to increase this font size? An even better solution might be to display the account name using something like 'Text Display for Study'. This would allow me to easily position it in a different corner. However, I'm unsure if this functionality is available. Thanks! Date Time Of Last Edit: 2024-04-12 12:39:07
Private File |
| [2024-04-12 14:36:07] |
| John - SC Support - Posts: 47918 |
The Trading Account name in the upper left is part of the general text. So the only way to change the size is to change the size of all the chart text through the "Chart Text" font. Refer to the following: Graphics Settings: Chart Text There is not another built-in option that will let you access the Trading Account to be able to display it elsewhere. You can create a custom study that would do this. Refer to the following: ACSIL Interface Members - Variables and Arrays: sc.SelectedTradeAccount List of Third Party Sierra Chart Study and System Programmers For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-09-29 12:17:11] |
| User658398 - Posts: 1 |
Hello where in the settings can you change what information should be displayed in the upper left window symbol / contract / time scale etc. Is it possible to reduce the amount of this information? Thank you in advance |
| Attachment Deleted. |
| [2024-09-30 13:44:51] |
Refer to the following: Global Settings Menu: Customize Chart Header - Standard (Global Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
