Date/Time: Mon, 25 Nov 2024 00:47:21 +0000
Possibility to lock the regions ?
View Count: 308
[2024-04-12 10:02:21] |
User246799 - Posts: 13 |
Hello, Is it possible to lock the height of the regions please ? I mean define and lock a specific height for each region but still being able to interact on the graph inside this region (keep the interactive scale range for a region but just lock the allocated space inside a chart). I didn't see any question or answer since 2021. If not, any evolution can be hoped as it would be really helpfull ? Thank you. |
[2024-04-12 14:23:48] |
There is not a way to "lock" the size of a region. Make sure the option for "Adjust Regions Tool Always Active with Current Tool" is set to "No" in order to not have the regions be able to be changed in the main graph area, but only through the vertical scale. Refer to the following: Chart Drawing Tools: Adjust Regions Tool Always Active With Current Tool (Global Settings >> Tool Settings >> General >> Tool Options) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-14 18:27:05] |
Ok, thank you. This setting is not perfect but it helps. Thx.
