Date/Time: Sun, 24 Nov 2024 23:53:51 +0000
Price scale issue with Additional symbol study
View Count: 210
[2024-04-12 00:09:11]
aseef - Posts: 49
I have applied ES as additional symbol to the chart, but the price scale has showing price differently (probably decimal moved 2 places on right). Which I unable to fix. I have attached pictures for reference.
image1.png / V - Attached On 2024-04-12 00:08:54 UTC - Size: 157.88 KB - 59 views
image2.png / V - Attached On 2024-04-12 00:08:57 UTC - Size: 51.95 KB - 59 views
[2024-04-12 14:03:23]
What is the exact symbol you entered for the Add Additional Symbol study?
[2024-04-13 00:18:45]
aseef - Posts: 49
ESM24_FUT_CME
[2024-04-17 01:55:46]
Sierra_Chart Engineering - Posts: 17163
Refer to this Input setting:
Add Additional Symbol: Price Multipler
Set it to .01.
Date Time Of Last Edit: 2024-04-17 01:56:04
[2024-04-17 10:21:24]
aseef - Posts: 49
Thanks Solved
