Date/Time: Sat, 31 Oct 2026 18:47:03 +0000
Draw Styles & Secondary TPOC
View Count: 721
[2024-04-11 22:56:50]
User688525 - Posts: 401
Hello Sierra Chart,
Is it possible to add the following "Draw Styles" for the "Volume At Price Threshold Alert V2" study:
- Point offset left candlestick
- Arrow offset left candlestick
- Diamond offset left candlestick
Also, is there a way to display the secondary TPOC on a chart which would indicate where the TPOC is likely to shift to. Note, this is different to the current TPOC which can be displayed using the "TPO Value Area Lines"?
Thank you!
[2024-04-12 13:33:01]
These would all be items that would need to be added. We have set this as a "Feature Request. We can not say when we would get to any particular request.
[2024-04-12 17:08:23]
Thank you very much John.
[2026-02-23 00:39:18]
Sierra_Chart Engineering - Posts: 25330
We are looking this over. What is TPOC?
[2026-02-23 03:15:15]
TPOC = TPO Point of Control
This is the time-based POC.
[2026-02-23 04:36:05]
How is this calculated ? How is it different from the standard Point of Control calculation:
[2026-02-23 07:00:56]
How is it different from the standard Point of Control calculation? The only difference is that this is the next most populated TPO row(s) after the main timewise POC.
