Date/Time: Sun, 19 May 2024 00:28:44 +0000
Trading the Nines
View Count: 97
[2024-04-11 20:01:41] |
hdanng221 - Posts: 3 |
Hi, Is it possible to create an alert based on a certain number in the "Trading the Nines" sequencer like no. 2? I'm trying to create an alert when each candle with a 2 above or below is labeled with the condition that it's above the Keltner Avg. I have the latter part figured out but not the first. Much thanks! |
[2024-04-11 21:54:31] |
The number that is displayed about the bar is the value of the Subgraph for "Buy Number" or "Sell Number". So if you want an alert when the Buy Number has a value of 2, then you would use an alert formula that looks like the following: =ID1.SG1 = 2 Where ID1 is the ID of the "Trading the Nines" study and SG1 is the "Buy Number" subgraph. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
