Date/Time: Sat, 18 May 2024 23:29:42 +0000
Graphics for line
View Count: 112
[2024-04-11 19:46:22] |
karohm - Posts: 137 |
Uploading a picture of trendline compared to Tradingview. The trendline is not as perfect looking like in Tradingview. The color, line and the pixels are breaking up. Dont know if I have something wrong in SC (Open GL is turned on) or if this is the best it looks. |
Private File Private File |
[2024-04-12 06:38:23] |
Update : I switched my monitor to my GPU and It has gotten better but still not the best (like TV). I am still seeing some breaks in the lines which are not straight. I am not sure if this is the best it gets. Uploading the updated screenshot compared to TV. If you zoom in a lil you'll notice the breaks. Left is TV and the right is SC Thanks |
Screen Shot Fri 04 12 2024 at 2.32 AM.png / V - Attached On 2024-04-12 06:37:57 UTC - Size: 74.68 KB - 39 views |
[2024-04-12 07:48:12] |
Sierra_Chart Engineering - Posts: 14423 |
This not within the scope of our support. The other line is drawn with 4 colors and uses an optical illusion to trick you into thinking it is smooth when it is not.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-04-12 07:48:52
