Date/Time: Sat, 18 May 2024 23:29:57 +0000
Executions are not recorded correctly
View Count: 110
[2024-04-11 19:12:13] |
esasa - Posts: 3 |
Hi, I have this problem now for a while. I believe this started after the last update. It is on Apex PA and eval accounts. I buy/sell and when price hits tp it draws a line from a position from yesterday or before. It completely messes up PL. Please check my screenshot. As you might know, there is no holding overnight with Apex accounts. What is happening? It make SC completely unreliable to me. Is there any way to fix this and reset the recorded positions. Greetings Saša |
sc-20240412-020446-broken-executions.png / V - Attached On 2024-04-11 19:11:29 UTC - Size: 351.49 KB - 30 views |
[2024-04-11 21:42:25] |
Go through the items at the following link: Help With Daily Profit/Loss Value For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-12 07:58:43] |
Sierra_Chart Engineering - Posts: 14423 |
Also refer to: Chart Trading and the Chart DOM: Accurate Entry/Exit State, Fill Matching and Position Quantities Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
