Date/Time: Sun, 19 May 2024 03:15:25 +0000
Is there a way to tell what type of spreadsheet was selected?
View Count: 77
[2024-04-11 16:52:55] |
SSGill - Posts: 35 |
In a current chart book, I have several spreadsheets. Is there way to tell if the existing spreadsheet selected was an Alert or a Trade worksheet? The reason I am asking is because the alert and trade sheets have 4 columns for entry and exits.
[2024-04-11 17:29:15] |
You would have to look at the Study Selection window (Analysis >> Studies) where it will give you the actual file that is associated with the spreadsheet. You could also open the Settings for each to see which file is being used. That file is what is shown in the tab for the spreadsheet. Refer to the following: Chart Studies: Settings and Inputs Tab >> Spreadsheet Name / DLL File and Function Name For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
