Date/Time: Sun, 19 May 2024 00:28:31 +0000
Volume by price not anchoring correctly
View Count: 77
[2024-04-11 15:59:52] |
User701530 - Posts: 9 |
I want to use the volume by price study to show a volume profile for each session with a separate profile for the evening session. In settings I've selected "Multiple profiles based on a fixed time" and "Day" for time period type. I've also selected "yes" for use separate profile for evening session. The problem I'm having is the profiles are not anchored at the correct times start times.
[2024-04-11 17:12:24] |
With this setup the profiles are going to be "anchored" where the Session Times are set for your chart. Refer to the following: Chart Session Times For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
