Date/Time: Sat, 04 May 2024 10:58:37 +0000
can
View Count: 64
[2024-04-10 17:13:01] |
User335019 - Posts: 3 |
Hi there, Say that... stage 1.. a spreadsheet displays (flowing) 500 lines coming live from a chart X; stage 2.. using formulas, i recalculate these flowing data cells and write them to other part of the spreadsheet. stage 3.. want to "graphically display" this recalculated new "500 cell lines"; On a study of any chart (same X or Y or Z) Q1.. Is it posssible to do it with built in tools ? Q2.. If not; is it possible to do it by C++ coding a "study" ? Thanks in advance. |
[2024-04-10 17:15:03] |
John - SC Support - Posts: 31362 |
What you are describing is exactly what the "Spreadsheet Study" does. By default only columns K, L, M, and N are set to display on the chart, but you can change this in the Subgraph settings to display any column from K through BR. Refer to the information here: Using the Spreadsheet Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
