Date/Time: Sat, 04 May 2024 15:56:35 +0000
Two trading services: one for execution and one for data/market depth
View Count: 124
[2024-04-10 14:42:49] |
User308424 - Posts: 68 |
Hi there SC support team, I am working with evaluation account which use Rithmic. I think all of eval account use Rithmic. Rithmic causes a lot of issues to me as very often data I get from them is delayed. I wanted to check with you if combination of trade execution via Rithmic user/account together with Denali Data Feed from you would be possible. Basically I want to see Denali market depth to make my trading decision but the execution should go via Rithmic eval account. I found this post but its not really clear to me: Using Multiple Data and Trading Services at the Same Time Would you be so kind and assist me with that please? Thanks in advance! |
[2024-04-10 16:25:45] |
John - SC Support - Posts: 31362 |
Basically I want to see Denali market depth to make my trading decision but the execution should go via Rithmic eval account. Yes, this is possible, and is how Sierra Chart is setup. The information you want is at the following link: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services Just keep in mind that since you will be wanting data for the CME Group, you need to have a live, funded, futures trading account that is not a prop firm account. Refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges If you do not have an account that will qualify for the above, then we recommend the solution outlined at the following link: Easy Solution to CME Funded Trading Account Requirement Once you have the above worked out, then follow the instructions at the following link to setup the data for the CME Group from our Denali Exchange Data Feed: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-11 06:49:30] |
Hi John, thanks for the detailed explanation. Resolved! Date Time Of Last Edit: 2024-04-11 14:29:32
