Date/Time: Mon, 20 May 2024 21:44:46 +0000
Any way to change text size on the
View Count: 77
[2024-04-10 13:08:47] |
User92573 - Posts: 491 |
Dear Support Clearly we can modify the text parameters for the text tools but is there anyway we can, or will we in the future be able to do the same with the text that is attached to the various line tools when using modify text? Many thanks. |
[2024-04-10 16:19:57] |
John - SC Support - Posts: 31754 |
For drawings that do not have their own text controls (such as Line) the text size and style is set by the "Global Drawing Font". Refer to the following: Chart Drawing Tools: Global Chart Drawing Font (Global Settings >> Tool Settings >> General >> Drawing Font) This is a global setting, so changing it will change all the text for drawings that depend on this item. There is not a way to change it for individual drawings. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
