Date/Time: Mon, 20 May 2024 19:33:21 +0000
Market Depth Historical Grapg queeries
View Count: 92
[2024-04-10 11:08:14] |
ernie Suarez - Posts: 6 |
Hi There, I am currently using the market depth historical graph study and have set this to only show the range 3 max ask color (red) and range 3 max bid color (green). However, today on the 10th of April 2024, there is a green line showing above the price line which doesn't make sense for a bid order. Would you kindly provide an explanation as to what this is or why is this happening? Thank you. https://www.sierrachart.com/image.php?Image=1712747172411.png |
[2024-04-10 16:12:50] |
John - SC Support - Posts: 31746 |
It is possible that there could be Bid orders above the current price point. It is odd for them to be the largest values at that time, however. Please set the following and get us another image: - Show Quantity Numbers: In Bars and After Last Bar - Bid Quantity Numbers Color: Set this to something that is visible in the green. - Ask Quantity Numbers Color: Set this to something that is visible in the red. Make sure the Bid and Ask quantity colors are not the same, we need to see the different values and know which are which. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
