Date/Time: Mon, 25 Nov 2024 00:39:56 +0000
lines in the DOM window
View Count: 176
[2024-04-10 06:50:44] |
User765147 - Posts: 9 |
lines in the DOM window While trading, sometimes yellow lines appear in the DOM window, lines that can be dragged up or down I don't want these lines it interferes with my trading It happened to me several times that instead of dragging the stop or the limit I dragged the line How can you cancel the creation of these lines? |
Attachment Deleted. MESM24_FUT_CME [CBV][M] #2 2024-04-10 02_48_14.473.png / V - Attached On 2024-04-10 06:49:31 UTC - Size: 48.84 KB - 56 views |
[2024-04-10 15:38:28] |
We do not know for sure where those are coming from, it is something you will need to determine. Our best guess, since you state that you can move them, is that they are copied drawings. Refer to the following: Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu) Also check if you have any studies that are on that chart and possibly remove them, although you should not be able to move study lines. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
