Date/Time: Sat, 20 Apr 2024 09:31:34 +0000
Package upgrade
View Count: 1951
[2013-05-06 20:01:49] |
BradLewis - Posts: 1 |
I want to upgrade my account but when I try to do so I get a message that my account does not allow package upgrade? Please advise. Thanks, Brad |
[2013-05-06 22:35:08] |
To what package do you want to go to?
[2013-05-06 22:39:47] |
Sierra Chart - Max - Posts: 5590 |
You will need to contact Greenchart to request a package change.
Sierra Chart Support |
