Date/Time: Wed, 01 May 2024 07:33:14 +0000
One stock is not updating during day
View Count: 91
[2024-04-08 21:56:52] |
User682444 - Posts: 8 |
I have the Denali feed with Composite stocks. All other stocks update real time during the day but AMD does not. AMD did update for a few days but now it will only update at the end of the day. What do I need to fix? |
[2024-04-08 22:57:40] |
John - SC Support - Posts: 31240 |
There is no reason to have any issues with AMD in particular. You are setup to get the real-time data for the U.S. Equities Consolidated Tape. The one thing we want to make sure of is that you are entering the symbol as just "AMD" (no quotes). If the chart has a different symbol, then please let us know what it is. Otherwise, please get us your Message Log by following these instructions: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-09 03:47:42] |
Sierra_Chart Engineering - Posts: 14161 |
Also: Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings And disable custom symbol settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-09 15:22:33] |
From user: 2024-04-08 16:11:00.436 | Software version: 2621 64-bit 2024-04-08 16:11:00.470 | OpenGL enabled (NVIDIA Corporation/NVIDIA GeForce GTX 660/PCIe/SSE2) 2024-04-08 16:11:00.470 | Primary Thread ID: 774840 2024-04-08 16:11:00.470 | Usage end date: 2024-09-17 2024-04-08 16:11:00.470 | Enabled for: Advanced Features 2. 2024-04-08 16:11:00.470 | Enabled for: Sierra Chart Historical Data Service. 2024-04-08 16:11:00.470 | Enabled for: Denali Real-Time Exchange Data Feed. 2024-04-08 16:11:00.470 | Enabled for: Delayed Denali Exchange Data Feed. 2024-04-08 16:11:00.470 | Enabled for exchange2: CME 2024-04-08 16:11:00.470 | Enabled for exchange2: US Equities Consolidated Tape 2024-04-08 16:11:00.470 | Allow Support for Sierra Chart Data Feeds is enabled. 2024-04-08 16:11:00.470 | Current selected Data/Trading service: SC Data - All Services 2024-04-08 16:11:00.470 | Custom symbol settings values: enabled 2024-04-08 16:11:00.470 | Chart Update Interval: 500 2024-04-08 16:11:00.470 | Intraday Data Storage Time Unit: 0 2024-04-08 16:11:00.470 | Time Zone: -07:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) 2024-04-08 16:11:00.470 | 2024-04-08 23:11:00 Local computer time in UTC 2024-04-08 16:11:00.470 | 2024-04-08 16:11:00 Local computer time in SC Time Zone 2024-04-08 16:11:00.470 | 2024-04-07 18:24:41 Server time in UTC 2024-04-08 16:11:00.470 | Local computer UTC time and Server UTC time difference: 0 seconds. 2024-04-08 16:11:00.470 | Program path: C:\SierraChart\ 2024-04-08 16:11:00.470 | Data Files path: C:\SierraChart\Data\ 2024-04-08 16:11:00.470 | OS Version Number: 10.0 2024-04-08 16:11:00.470 | Locale Setting: C 2024-04-08 16:11:00.471 | DLLs: Convergent_64.dll, DelDivatBar_1_64.dll, HAUSPRICE5_64.dll, Hausprice_64.dll, HausTrades_64.dll, Levex_64.dll, MomoBot_64.dll, old Levex.dll, RelativeVolume.dll, S3_V3.4_64.dll, S3_V4_64.dll, sst_FreeBundle_2273_64.dll, sst_FreeBundle_64.dll, sst_oiltradinggroup_2151_64.dll, T3_V3.4_64.dll, T3_V4_64.dll, TheReverser_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll 2024-04-08 16:11:00.471 | Allowed protected custom studies: OTG_MML, SST_FreeBundle, zyp_app 2024-04-08 16:11:00.471 | Crash reporter started: true 2024-04-08 16:11:00.471 | 2024-04-08 16:11:45.509 | Saved Chartbook: QQQ.CHT. Time: 0.0835 seconds. 2024-04-08 16:11:45.581 | Saved Chartbook: COIN.Cht. Time: 0.0709 seconds. 2024-04-08 16:11:45.676 | Saved Chartbook: PFE.Cht. Time: 0.0941 seconds. 2024-04-08 16:11:45.774 | Saved Chartbook: PBR.Cht. Time: 0.0968 seconds. 2024-04-08 16:11:45.867 | Saved Chartbook: QCOM.Cht. Time: 0.0924 seconds. 2024-04-08 16:11:45.924 | Saved Chartbook: TMV.Cht. Time: 0.0555 seconds. 2024-04-08 16:11:46.039 | Saved Chartbook: SOXL.Cht. Time: 0.1141 seconds. 2024-04-08 16:11:46.059 | Saved Chartbook: NVDA.Cht. Time: 0.0192 seconds. 2024-04-08 16:11:46.153 | Saved Chartbook: SLV.Cht. Time: 0.0933 seconds. 2024-04-08 16:11:46.234 | Saved Chartbook: GLD.Cht. Time: 0.0801 seconds. 2024-04-08 16:11:46.336 | Saved Chartbook: MSFT.Cht. Time: 0.1010 seconds. 2024-04-08 16:11:46.426 | Saved Chartbook: GOOGL.Cht. Time: 0.0888 seconds. 2024-04-08 16:11:46.520 | Saved Chartbook: ACB.Cht. Time: 0.0929 seconds. 2024-04-08 16:11:46.545 | Saved Chartbook: NQ SET.CHT. Time: 0.0244 seconds. 2024-04-08 16:11:46.698 | Saved Chartbook: AMD.Cht. Time: 0.1521 seconds. 2024-04-08 16:11:46.787 | Saved Chartbook: DELL.CHT. Time: 0.0873 seconds. 2024-04-08 16:11:46.800 | Saved Chartbook: ES SET.CHT. Time: 0.0119 seconds. 2024-04-08 16:11:56.194 | Saved Chartbook: QQQ.CHT. Time: 0.0746 seconds. 2024-04-08 16:11:56.275 | Saved Chartbook: COIN.Cht. Time: 0.0802 seconds. 2024-04-08 16:11:56.403 | Saved Chartbook: PFE.Cht. Time: 0.1268 seconds. 2024-04-08 16:11:56.502 | Saved Chartbook: PBR.Cht. Time: 0.0979 seconds. 2024-04-08 16:11:56.594 | Saved Chartbook: QCOM.Cht. Time: 0.0910 seconds. 2024-04-08 16:11:56.660 | Saved Chartbook: TMV.Cht. Time: 0.0650 seconds. 2024-04-08 16:11:56.772 | Saved Chartbook: SOXL.Cht. Time: 0.1108 seconds. 2024-04-08 16:11:56.791 | Saved Chartbook: NVDA.Cht. Time: 0.0181 seconds. 2024-04-08 16:11:56.910 | Saved Chartbook: SLV.Cht. Time: 0.1173 seconds. 2024-04-08 16:11:56.999 | Saved Chartbook: GLD.Cht. Time: 0.0877 seconds. 2024-04-08 16:11:57.099 | Saved Chartbook: MSFT.Cht. Time: 0.0989 seconds. 2024-04-08 16:11:57.201 | Saved Chartbook: GOOGL.Cht. Time: 0.1015 seconds. 2024-04-08 16:11:57.294 | Saved Chartbook: ACB.Cht. Time: 0.0920 seconds. 2024-04-08 16:11:57.319 | Saved Chartbook: NQ SET.CHT. Time: 0.0236 seconds. 2024-04-08 16:11:57.427 | Saved Chartbook: AMD.Cht. Time: 0.1071 seconds. 2024-04-08 16:11:57.517 | Saved Chartbook: DELL.CHT. Time: 0.0892 seconds. 2024-04-08 16:11:57.532 | Saved Chartbook: ES SET.CHT. Time: 0.0136 seconds. 2024-04-08 16:12:05.687 | Unsubscribed from market depth data for NQM24-CME 2024-04-08 16:12:28.897 | AMD 1 Min #1 | Reloading chart. 2024-04-08 16:12:29.399 | Added historical Intraday data request for AMD to the queue. 2024-04-08 16:12:29.399 | Intraday data recording state for symbol AMD is set to download 'Pending'. 2024-04-08 16:12:29.399 | Triggering next historical data download in queue. 2024-04-08 16:12:29.399 | HD Request # 115 | Downloading Intraday chart data for AMD to the file AMD.scid. Service: scdataallservices 2024-04-08 16:12:29.400 | HD Request # 115 | Download start date-time: 2024-04-08 13:44:00.000000. File last date-time: 2024-04-08 13:44:00.000000 2024-04-08 16:12:29.743 | HD Request # 115 | Requesting historical Intraday Minute data for AMD starting at 2024-04-08 16:44:00 (Exchange time). 2024-04-08 16:12:30.106 | AMD 1 Min #1 | Chart data loading complete. 2024-04-08 16:12:30.183 | HD Request # 115 | Receiving Intraday data for AMD starting at 2024-04-08 13:44:00.000000 2024-04-08 16:12:30.183 | HD Request # 115 | Bytes received: 58 2024-04-08 16:12:30.183 | HD Request # 115 | Received 1 Intraday data record from 2024-04-08 13:44:00.000000 to 2024-04-08 13:44:00.000000 (0.0 seconds. Delay: 2.5 hours) and wrote 0 records for AMD 2024-04-08 16:12:30.184 | HD Request # 115 | Add time&sales data | Remembered last file record date-time: 2024-04-08 20:44:00.000000 2024-04-08 16:12:30.184 | HD Request # 115 | Completion time: 1s. 2024-04-08 16:12:30.184 | HD Request # 115 | Intraday data download complete for AMD. Unique request ID: 137 2024-04-08 16:12:30.184 | Removing historical data download ID 137. 2024-04-08 16:12:30.184 | Real-time Intraday chart data file updates started for AMD 2024-04-08 16:12:30.184 | Intraday chart data file opened for AMD 2024-04-08 16:12:30.184 | HD Request # 115 | Enabling Intraday chart updating for symbol. 2024-04-08 16:12:30.184 | 2024-04-08 16:12:30.184 | No download requests in the queue to start downloads for. 2024-04-08 16:12:54.006 | File >> Disconnect selected. 2024-04-08 16:12:54.009 | Denali Data Feed | Waiting for socket receive thread to end 2024-04-08 16:12:54.009 | DTC Client socket (12) | CloseSocket call. 2024-04-08 16:12:54.009 | DTC Client socket (12) | Max send buffers used during socket life: 4 2024-04-08 16:12:54.009 | DTC Client socket (12) | Max send buffer size during socket life: 3496 2024-04-08 16:12:54.009 | DTC Client socket (12) | Shutdown started. Waiting for graceful close. 2024-04-08 16:12:54.009 | Denali Data Feed | Disconnected from the server. 2024-04-08 16:12:54.009 | Denali Data Feed | Waiting for socket receive thread to end 2024-04-08 16:12:54.010 | DTC Client socket (14) | CloseSocket call. 2024-04-08 16:12:54.010 | DTC Client socket (14) | Shutdown started. Waiting for graceful close. 2024-04-08 16:12:54.010 | Denali Data Feed | Disconnected from the server. 2024-04-08 16:12:54.010 | SC Data with Depth | Waiting for socket receive thread to end 2024-04-08 16:12:54.011 | DTC Client socket (15) | CloseSocket call. 2024-04-08 16:12:54.011 | DTC Client socket (15) | Shutdown started. Waiting for graceful close. 2024-04-08 16:12:54.011 | SC Data with Depth | Disconnected from the server. 2024-04-08 16:12:54.011 | Delayed Data Feed | Waiting for socket receive thread to end 2024-04-08 16:12:54.012 | DTC Client socket (11) | CloseSocket call. 2024-04-08 16:12:54.012 | DTC Client socket (11) | Shutdown started. Waiting for graceful close. 2024-04-08 16:12:54.012 | Delayed Data Feed | Disconnected from the server. 2024-04-08 16:12:54.012 | SC Data - All Services | Disconnected. 2024-04-08 16:12:54.089 | DTC Client socket (11) | Socket gracefully closed by remote side. 2024-04-08 16:12:54.089 | DTC Client socket (11) | Closed. 2024-04-08 16:12:54.091 | DTC Client socket (15) | Socket gracefully closed by remote side. 2024-04-08 16:12:54.091 | DTC Client socket (15) | Closed. 2024-04-08 16:12:54.161 | DTC Client socket (12) | Socket gracefully closed by remote side. 2024-04-08 16:12:54.161 | DTC Client socket (12) | Closed. 2024-04-08 16:12:54.204 | DTC Client socket (14) | Socket gracefully closed by remote side. 2024-04-08 16:12:54.204 | DTC Client socket (14) | Closed. 2024-04-08 16:13:01.486 | 2024-04-08 16:13:01.486 | SC Data - All Services | Connected to server complete. 2024-04-08 16:13:01.489 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-04-08 16:13:01.743 | Mapping TSLA to TSLA. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.743 | Using symbol data fast lookup vector 2024-04-08 16:13:01.743 | Denali Data Feed | Starting real-time market data updates for: TSLA (TSLA). ID: 1 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.743 | Denali Data Feed | Connecting to the server ds30.sierracharts.com. Port 443 2024-04-08 16:13:01.743 | Denali Data Feed | Requesting security definition data for: TSLA (TSLA). ID: 1 2024-04-08 16:13:01.743 | Mapping NVDA to NVDA. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.743 | Denali Data Feed | Starting real-time market data updates for: NVDA (NVDA). ID: 2 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.743 | Denali Data Feed | Requesting security definition data for: NVDA (NVDA). ID: 2 2024-04-08 16:13:01.744 | Mapping NFLX to NFLX. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.744 | Denali Data Feed | Starting real-time market data updates for: NFLX (NFLX). ID: 3 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.744 | Denali Data Feed | Requesting security definition data for: NFLX (NFLX). ID: 3 2024-04-08 16:13:01.744 | Mapping HD to HD. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.744 | Denali Data Feed | Starting real-time market data updates for: HD (HD). ID: 4 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.744 | Denali Data Feed | Requesting security definition data for: HD (HD). ID: 4 2024-04-08 16:13:01.744 | Mapping CLk24-NYMEX to CLK24. Service code: nymex 2024-04-08 16:13:01.744 | Delayed Data Feed | Starting real-time market data updates for: CLk24-NYMEX (CLK24). ID: 5 Service code: nymex 2024-04-08 16:13:01.744 | Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 2024-04-08 16:13:01.744 | Delayed Data Feed | Requesting security definition data for: CLk24-NYMEX (CLK24). ID: 5 2024-04-08 16:13:01.744 | DTC Client socket (1) | Creating socket. 2024-04-08 16:13:01.744 | Mapping MESM24-CME to MESM24. Service code: cme 2024-04-08 16:13:01.744 | Denali Data Feed | Starting real-time market data updates for: MESM24-CME (MESM24). ID: 6 Service code: cme 2024-04-08 16:13:01.744 | DTC Client socket (1) | New receive buffer size: 0 2024-04-08 16:13:01.744 | Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 443 2024-04-08 16:13:01.744 | DTC Client socket (1) | Connecting to IP: 38.103.112.195. 2024-04-08 16:13:01.744 | Denali Data Feed | Requesting security definition data for: MESM24-CME (MESM24). ID: 6 2024-04-08 16:13:01.745 | Mapping AAPL to AAPL. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.745 | Denali Data Feed | Starting real-time market data updates for: AAPL (AAPL). ID: 7 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.745 | Denali Data Feed | Requesting security definition data for: AAPL (AAPL). ID: 7 2024-04-08 16:13:01.745 | Mapping QQQ to QQQ. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.745 | Denali Data Feed | Starting real-time market data updates for: QQQ (QQQ). ID: 8 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.745 | Denali Data Feed | Requesting security definition data for: QQQ (QQQ). ID: 8 2024-04-08 16:13:01.745 | Mapping SLV to SLV. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.745 | Denali Data Feed | Starting real-time market data updates for: SLV (SLV). ID: 9 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.745 | Denali Data Feed | Requesting security definition data for: SLV (SLV). ID: 9 2024-04-08 16:13:01.745 | Mapping ACB to ACB. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.745 | Denali Data Feed | Starting real-time market data updates for: ACB (ACB). ID: 10 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.745 | Denali Data Feed | Requesting security definition data for: ACB (ACB). ID: 10 2024-04-08 16:13:01.745 | Mapping VNO to VNO. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.745 | Denali Data Feed | Starting real-time market data updates for: VNO (VNO). ID: 11 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.745 | Denali Data Feed | Requesting security definition data for: VNO (VNO). ID: 11 2024-04-08 16:13:01.745 | SC Data with Depth | Starting real-time market data updates for: NVOL24H-NQ. ID: 12 Service code: statscalc 2024-04-08 16:13:01.745 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 2024-04-08 16:13:01.745 | SC Data with Depth | Requesting security definition data for: NVOL24H-NQ. ID: 12 2024-04-08 16:13:01.745 | SC Data with Depth | Starting real-time market data updates for: NVOL24H-NYSE. ID: 13 Service code: statscalc 2024-04-08 16:13:01.745 | SC Data with Depth | Requesting security definition data for: NVOL24H-NYSE. ID: 13 2024-04-08 16:13:01.745 | Mapping GOOGL to GOOGL. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.745 | Denali Data Feed | Starting real-time market data updates for: GOOGL (GOOGL). ID: 14 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.745 | Denali Data Feed | Requesting security definition data for: GOOGL (GOOGL). ID: 14 2024-04-08 16:13:01.745 | Mapping MYMM24-CBOT to MYMM24. Service code: cbot 2024-04-08 16:13:01.745 | Delayed Data Feed | Starting real-time market data updates for: MYMM24-CBOT (MYMM24). ID: 15 Service code: cbot 2024-04-08 16:13:01.745 | Delayed Data Feed | Requesting security definition data for: MYMM24-CBOT (MYMM24). ID: 15 2024-04-08 16:13:01.745 | Mapping ZBM24-CBOT to ZBM24. Service code: cbot 2024-04-08 16:13:01.745 | Delayed Data Feed | Starting real-time market data updates for: ZBM24-CBOT (ZBM24). ID: 16 Service code: cbot 2024-04-08 16:13:01.745 | Delayed Data Feed | Requesting security definition data for: ZBM24-CBOT (ZBM24). ID: 16 2024-04-08 16:13:01.745 | Mapping TLT to TLT. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.746 | Denali Data Feed | Starting real-time market data updates for: TLT (TLT). ID: 17 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.746 | Denali Data Feed | Requesting security definition data for: TLT (TLT). ID: 17 2024-04-08 16:13:01.746 | Mapping ARM to ARM. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.746 | Denali Data Feed | Starting real-time market data updates for: ARM (ARM). ID: 18 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.746 | Denali Data Feed | Requesting security definition data for: ARM (ARM). ID: 18 2024-04-08 16:13:01.746 | Mapping DJT to DJT. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.746 | Denali Data Feed | Starting real-time market data updates for: DJT (DJT). ID: 19 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.746 | Denali Data Feed | Requesting security definition data for: DJT (DJT). ID: 19 2024-04-08 16:13:01.746 | Mapping SOUN to SOUN. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.746 | Denali Data Feed | Starting real-time market data updates for: SOUN (SOUN). ID: 20 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.746 | Denali Data Feed | Requesting security definition data for: SOUN (SOUN). ID: 20 2024-04-08 16:13:01.746 | Mapping RDDT to RDDT. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.746 | Denali Data Feed | Starting real-time market data updates for: RDDT (RDDT). ID: 21 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.746 | Denali Data Feed | Requesting security definition data for: RDDT (RDDT). ID: 21 2024-04-08 16:13:01.746 | SC Data - All Services | Starting real-time market data updates for: AMD. ID: 22 2024-04-08 16:13:01.746 | SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: AMD 2024-04-08 16:13:01.746 | SC Data - All Services | Requesting security definition data for: AMD. ID: 22 2024-04-08 16:13:01.746 | Mapping CGC to CGC. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.746 | Denali Data Feed | Starting real-time market data updates for: CGC (CGC). ID: 23 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.746 | Denali Data Feed | Requesting security definition data for: CGC (CGC). ID: 23 2024-04-08 16:13:01.746 | Mapping ALAB to ALAB. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.746 | Denali Data Feed | Starting real-time market data updates for: ALAB (ALAB). ID: 24 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.746 | Denali Data Feed | Requesting security definition data for: ALAB (ALAB). ID: 24 2024-04-08 16:13:01.746 | Mapping MSFT to MSFT. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.746 | Denali Data Feed | Starting real-time market data updates for: MSFT (MSFT). ID: 25 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.746 | Denali Data Feed | Requesting security definition data for: MSFT (MSFT). ID: 25 2024-04-08 16:13:01.746 | Mapping META to META. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.746 | Denali Data Feed | Starting real-time market data updates for: META (META). ID: 26 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.747 | Denali Data Feed | Requesting security definition data for: META (META). ID: 26 2024-04-08 16:13:01.747 | SC Data with Depth | Starting real-time market data updates for: TICK-NQ. ID: 27 Service code: statscalc 2024-04-08 16:13:01.747 | SC Data with Depth | Requesting security definition data for: TICK-NQ. ID: 27 2024-04-08 16:13:01.747 | Mapping AMZN to AMZN. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.747 | Denali Data Feed | Starting real-time market data updates for: AMZN (AMZN). ID: 28 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.747 | Denali Data Feed | Requesting security definition data for: AMZN (AMZN). ID: 28 2024-04-08 16:13:01.747 | SC Data with Depth | Starting real-time market data updates for: TRIN-NQ. ID: 29 Service code: statscalc 2024-04-08 16:13:01.747 | SC Data with Depth | Requesting security definition data for: TRIN-NQ. ID: 29 2024-04-08 16:13:01.747 | SC Data with Depth | Starting real-time market data updates for: TRIN-SP. ID: 30 Service code: statscalc 2024-04-08 16:13:01.747 | SC Data with Depth | Requesting security definition data for: TRIN-SP. ID: 30 2024-04-08 16:13:01.747 | SC Data with Depth | Starting real-time market data updates for: TICK-NYSE. ID: 31 Service code: statscalc 2024-04-08 16:13:01.747 | SC Data with Depth | Requesting security definition data for: TICK-NYSE. ID: 31 2024-04-08 16:13:01.747 | Mapping XLP to XLP. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.747 | Denali Data Feed | Starting real-time market data updates for: XLP (XLP). ID: 32 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.747 | Denali Data Feed | Requesting security definition data for: XLP (XLP). ID: 32 2024-04-08 16:13:01.747 | Mapping XLU to XLU. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.747 | Denali Data Feed | Starting real-time market data updates for: XLU (XLU). ID: 33 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.747 | Denali Data Feed | Requesting security definition data for: XLU (XLU). ID: 33 2024-04-08 16:13:01.747 | Mapping IWM to IWM. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.747 | Denali Data Feed | Starting real-time market data updates for: IWM (IWM). ID: 34 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.747 | Denali Data Feed | Requesting security definition data for: IWM (IWM). ID: 34 2024-04-08 16:13:01.747 | Mapping DIA to DIA. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.747 | Denali Data Feed | Starting real-time market data updates for: DIA (DIA). ID: 35 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.747 | Denali Data Feed | Requesting security definition data for: DIA (DIA). ID: 35 2024-04-08 16:13:01.747 | Mapping SOXS to SOXS. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.747 | Denali Data Feed | Starting real-time market data updates for: SOXS (SOXS). ID: 36 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.747 | Denali Data Feed | Requesting security definition data for: SOXS (SOXS). ID: 36 2024-04-08 16:13:01.747 | Mapping MU to MU. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.747 | Denali Data Feed | Starting real-time market data updates for: MU (MU). ID: 37 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.747 | Denali Data Feed | Requesting security definition data for: MU (MU). ID: 37 2024-04-08 16:13:01.747 | Mapping SMH to SMH. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.747 | Denali Data Feed | Starting real-time market data updates for: SMH (SMH). ID: 38 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.747 | Denali Data Feed | Requesting security definition data for: SMH (SMH). ID: 38 2024-04-08 16:13:01.747 | Mapping XLV to XLV. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.747 | Denali Data Feed | Starting real-time market data updates for: XLV (XLV). ID: 39 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.747 | Denali Data Feed | Requesting security definition data for: XLV (XLV). ID: 39 2024-04-08 16:13:01.747 | Mapping XLK to XLK. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.747 | Denali Data Feed | Starting real-time market data updates for: XLK (XLK). ID: 40 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.747 | Denali Data Feed | Requesting security definition data for: XLK (XLK). ID: 40 2024-04-08 16:13:01.747 | Mapping MARA to MARA. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.747 | Denali Data Feed | Starting real-time market data updates for: MARA (MARA). ID: 41 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.747 | Denali Data Feed | Requesting security definition data for: MARA (MARA). ID: 41 2024-04-08 16:13:01.747 | Mapping DNUT to DNUT. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.747 | Denali Data Feed | Starting real-time market data updates for: DNUT (DNUT). ID: 42 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.747 | Denali Data Feed | Requesting security definition data for: DNUT (DNUT). ID: 42 2024-04-08 16:13:01.747 | Mapping XLY to XLY. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.747 | Denali Data Feed | Starting real-time market data updates for: XLY (XLY). ID: 43 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.747 | Denali Data Feed | Requesting security definition data for: XLY (XLY). ID: 43 2024-04-08 16:13:01.748 | Mapping SPY to SPY. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.748 | Denali Data Feed | Starting real-time market data updates for: SPY (SPY). ID: 44 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.748 | Denali Data Feed | Requesting security definition data for: SPY (SPY). ID: 44 2024-04-08 16:13:01.748 | Mapping XLC to XLC. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.748 | Denali Data Feed | Starting real-time market data updates for: XLC (XLC). ID: 45 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.748 | Denali Data Feed | Requesting security definition data for: XLC (XLC). ID: 45 2024-04-08 16:13:01.748 | Mapping SMCI to SMCI. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.748 | Denali Data Feed | Starting real-time market data updates for: SMCI (SMCI). ID: 46 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.748 | Denali Data Feed | Requesting security definition data for: SMCI (SMCI). ID: 46 2024-04-08 16:13:01.748 | Mapping MSTR to MSTR. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.748 | Denali Data Feed | Starting real-time market data updates for: MSTR (MSTR). ID: 47 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.748 | Denali Data Feed | Requesting security definition data for: MSTR (MSTR). ID: 47 2024-04-08 16:13:01.748 | SC Data with Depth | Starting real-time market data updates for: ADR-SP. ID: 48 Service code: statscalc 2024-04-08 16:13:01.748 | SC Data with Depth | Requesting security definition data for: ADR-SP. ID: 48 2024-04-08 16:13:01.748 | SC Data with Depth | Starting real-time market data updates for: ADR-NQ. ID: 49 Service code: statscalc 2024-04-08 16:13:01.748 | SC Data with Depth | Requesting security definition data for: ADR-NQ. ID: 49 2024-04-08 16:13:01.748 | Mapping IBIT to IBIT. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.748 | Denali Data Feed | Starting real-time market data updates for: IBIT (IBIT). ID: 50 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.748 | Denali Data Feed | Requesting security definition data for: IBIT (IBIT). ID: 50 2024-04-08 16:13:01.748 | Mapping MNQM24-CME to MNQM24. Service code: cme 2024-04-08 16:13:01.748 | Denali Data Feed | Starting real-time market data updates for: MNQM24-CME (MNQM24). ID: 51 Service code: cme 2024-04-08 16:13:01.748 | Denali Data Feed | Requesting security definition data for: MNQM24-CME (MNQM24). ID: 51 2024-04-08 16:13:01.748 | Mapping BA to BA. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.748 | Denali Data Feed | Starting real-time market data updates for: BA (BA). ID: 52 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.748 | Denali Data Feed | Requesting security definition data for: BA (BA). ID: 52 2024-04-08 16:13:01.748 | Mapping PEP to PEP. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.748 | Denali Data Feed | Starting real-time market data updates for: PEP (PEP). ID: 53 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.748 | Denali Data Feed | Requesting security definition data for: PEP (PEP). ID: 53 2024-04-08 16:13:01.748 | Mapping GS to GS. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.748 | Denali Data Feed | Starting real-time market data updates for: GS (GS). ID: 54 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.748 | Denali Data Feed | Requesting security definition data for: GS (GS). ID: 54 2024-04-08 16:13:01.748 | Mapping CAT to CAT. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.748 | Denali Data Feed | Starting real-time market data updates for: CAT (CAT). ID: 55 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.748 | Denali Data Feed | Requesting security definition data for: CAT (CAT). ID: 55 2024-04-08 16:13:01.748 | Mapping ESM24-CME to ESM24. Service code: cme 2024-04-08 16:13:01.748 | Denali Data Feed | Starting real-time market data updates for: ESM24-CME (ESM24). ID: 56 Service code: cme 2024-04-08 16:13:01.748 | Denali Data Feed | Requesting security definition data for: ESM24-CME (ESM24). ID: 56 2024-04-08 16:13:01.748 | Mapping NQM24-CME to NQM24. Service code: cme 2024-04-08 16:13:01.748 | Denali Data Feed | Starting real-time market data updates for: NQM24-CME (NQM24). ID: 57 Service code: cme 2024-04-08 16:13:01.748 | Denali Data Feed | Requesting security definition data for: NQM24-CME (NQM24). ID: 57 2024-04-08 16:13:01.748 | Mapping COST to COST. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.748 | Denali Data Feed | Starting real-time market data updates for: COST (COST). ID: 58 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.748 | Denali Data Feed | Requesting security definition data for: COST (COST). ID: 58 2024-04-08 16:13:01.748 | Mapping AVGO to AVGO. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.748 | Denali Data Feed | Starting real-time market data updates for: AVGO (AVGO). ID: 59 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.748 | Denali Data Feed | Requesting security definition data for: AVGO (AVGO). ID: 59 2024-04-08 16:13:01.748 | Mapping MCD to MCD. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.748 | Denali Data Feed | Starting real-time market data updates for: MCD (MCD). ID: 60 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.748 | Denali Data Feed | Requesting security definition data for: MCD (MCD). ID: 60 2024-04-08 16:13:01.748 | Mapping ADBE to ADBE. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.748 | Denali Data Feed | Starting real-time market data updates for: ADBE (ADBE). ID: 61 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.748 | Denali Data Feed | Requesting security definition data for: ADBE (ADBE). ID: 61 2024-04-08 16:13:01.748 | Mapping V to V. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.748 | Denali Data Feed | Starting real-time market data updates for: V (V). ID: 62 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.748 | Denali Data Feed | Requesting security definition data for: V (V). ID: 62 2024-04-08 16:13:01.748 | Mapping LIN to LIN. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.748 | Denali Data Feed | Starting real-time market data updates for: LIN (LIN). ID: 63 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.748 | Denali Data Feed | Requesting security definition data for: LIN (LIN). ID: 63 2024-04-08 16:13:01.748 | Mapping CSCO to CSCO. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.748 | Denali Data Feed | Starting real-time market data updates for: CSCO (CSCO). ID: 64 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.748 | Denali Data Feed | Requesting security definition data for: CSCO (CSCO). ID: 64 2024-04-08 16:13:01.748 | Mapping AMGN to AMGN. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.748 | Denali Data Feed | Starting real-time market data updates for: AMGN (AMGN). ID: 65 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.748 | Denali Data Feed | Requesting security definition data for: AMGN (AMGN). ID: 65 2024-04-08 16:13:01.749 | Mapping UNH to UNH. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.749 | Denali Data Feed | Starting real-time market data updates for: UNH (UNH). ID: 66 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.749 | Denali Data Feed | Requesting security definition data for: UNH (UNH). ID: 66 2024-04-08 16:13:01.749 | Mapping DXYZ to DXYZ. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.749 | Denali Data Feed | Starting real-time market data updates for: DXYZ (DXYZ). ID: 67 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.749 | Denali Data Feed | Requesting security definition data for: DXYZ (DXYZ). ID: 67 2024-04-08 16:13:01.749 | Mapping BITO to BITO. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.749 | Denali Data Feed | Starting real-time market data updates for: BITO (BITO). ID: 68 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.749 | Denali Data Feed | Requesting security definition data for: BITO (BITO). ID: 68 2024-04-08 16:13:01.749 | Mapping COIN to COIN. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.749 | Denali Data Feed | Starting real-time market data updates for: COIN (COIN). ID: 69 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.749 | Denali Data Feed | Requesting security definition data for: COIN (COIN). ID: 69 2024-04-08 16:13:01.749 | Mapping VTYX to VTYX. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.749 | Denali Data Feed | Starting real-time market data updates for: VTYX (VTYX). ID: 70 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.749 | Denali Data Feed | Requesting security definition data for: VTYX (VTYX). ID: 70 2024-04-08 16:13:01.749 | Mapping VKTX to VKTX. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.749 | Denali Data Feed | Starting real-time market data updates for: VKTX (VKTX). ID: 71 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.749 | Denali Data Feed | Requesting security definition data for: VKTX (VKTX). ID: 71 2024-04-08 16:13:01.749 | Mapping PLTR to PLTR. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.749 | Denali Data Feed | Starting real-time market data updates for: PLTR (PLTR). ID: 72 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.749 | Denali Data Feed | Requesting security definition data for: PLTR (PLTR). ID: 72 2024-04-08 16:13:01.749 | Mapping SOXL to SOXL. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.749 | Denali Data Feed | Starting real-time market data updates for: SOXL (SOXL). ID: 73 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.749 | Denali Data Feed | Requesting security definition data for: SOXL (SOXL). ID: 73 2024-04-08 16:13:01.749 | Mapping CLSK to CLSK. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.749 | Denali Data Feed | Starting real-time market data updates for: CLSK (CLSK). ID: 74 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.749 | Denali Data Feed | Requesting security definition data for: CLSK (CLSK). ID: 74 2024-04-08 16:13:01.749 | Mapping BITX to BITX. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.749 | Denali Data Feed | Starting real-time market data updates for: BITX (BITX). ID: 75 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.749 | Denali Data Feed | Requesting security definition data for: BITX (BITX). ID: 75 2024-04-08 16:13:01.749 | Mapping RIOT to RIOT. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.749 | Denali Data Feed | Starting real-time market data updates for: RIOT (RIOT). ID: 76 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.749 | Denali Data Feed | Requesting security definition data for: RIOT (RIOT). ID: 76 2024-04-08 16:13:01.750 | Mapping QCOM to QCOM. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.750 | Denali Data Feed | Starting real-time market data updates for: QCOM (QCOM). ID: 77 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.750 | Denali Data Feed | Requesting security definition data for: QCOM (QCOM). ID: 77 2024-04-08 16:13:01.750 | Mapping CONL to CONL. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.750 | Denali Data Feed | Starting real-time market data updates for: CONL (CONL). ID: 78 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.750 | Denali Data Feed | Requesting security definition data for: CONL (CONL). ID: 78 2024-04-08 16:13:01.750 | Mapping FBTC to FBTC. Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.750 | Denali Data Feed | Starting real-time market data updates for: FBTC (FBTC). ID: 79 Service code: us_equities_utp_cta_exchange.data 2024-04-08 16:13:01.750 | Denali Data Feed | Requesting security definition data for: FBTC (FBTC). ID: 79 2024-04-08 16:13:01.819 | DTC Client socket (3) | Creating socket. 2024-04-08 16:13:01.819 | Denali Data Feed | Network connection to server complete. 2024-04-08 16:13:01.819 | Denali Data Feed | Starting socket receive thread. 2024-04-08 16:13:01.819 | DTC Client socket (3) | New receive buffer size: 0 2024-04-08 16:13:01.819 | DTC Client socket (3) | Connecting to IP: 38.103.112.188. 2024-04-08 16:13:01.819 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high 2024-04-08 16:13:01.819 | DTC Client socket (5) | Creating socket. 2024-04-08 16:13:01.819 | DTC Client socket (5) | New receive buffer size: 0 2024-04-08 16:13:01.819 | DTC Client socket (5) | Connecting to IP: 38.103.112.188. 2024-04-08 16:13:01.892 | DTC Client socket (6) | Creating socket. 2024-04-08 16:13:01.892 | DTC Client socket (6) | New receive buffer size: 0 2024-04-08 16:13:01.892 | DTC Client socket (6) | Connecting to IP: 38.103.112.181. 2024-04-08 16:13:01.897 | Delayed Data Feed | Network connection to server complete. 2024-04-08 16:13:01.897 | Delayed Data Feed | Starting socket receive thread. 2024-04-08 16:13:01.897 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-04-08 16:13:01.898 | Added historical Intraday data request for AMD to the queue. 2024-04-08 16:13:01.898 | Intraday data recording state for symbol AMD is set to download 'Pending'. 2024-04-08 16:13:01.898 | Triggering next historical data download in queue. 2024-04-08 16:13:01.905 | Denali Data Feed | Network connection to server complete. 2024-04-08 16:13:01.905 | Denali Data Feed | Starting socket receive thread. 2024-04-08 16:13:01.905 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-04-08 16:13:01.905 | Delaying start of download for AMD. 2024-04-08 16:13:01.918 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-04-08 16:13:01.918 | Denali Data Feed | Sending logon request message. 2024-04-08 16:13:01.973 | SC Data with Depth | Network connection to server complete. 2024-04-08 16:13:01.973 | SC Data with Depth | Starting socket receive thread. 2024-04-08 16:13:01.973 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard 2024-04-08 16:13:01.985 | Delayed Data Feed | Setting DTC encoding to Binary VLS 2024-04-08 16:13:01.985 | Delayed Data Feed | Sending logon request message. 2024-04-08 16:13:01.986 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-04-08 16:13:01.986 | Denali Data Feed | Sending logon request message. 2024-04-08 16:13:02.093 | SC Data with Depth | Setting DTC encoding to Binary VLS 2024-04-08 16:13:02.093 | SC Data with Depth | Sending logon request message. 2024-04-08 16:13:02.391 | Delayed Data Feed | Received logon response. 2024-04-08 16:13:02.391 | Delayed Data Feed | Server Name: SC Realtime Server. 2024-04-08 16:13:02.391 | Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 2024-04-08 16:13:02.391 | Delayed Data Feed | Successfully connected. 2024-04-08 16:13:02.391 | Delayed Data Feed | Trading is not supported. 2024-04-08 16:13:02.391 | Delayed Data Feed | MarketDepthIsSupported: 1 2024-04-08 16:13:02.391 | Delayed Data Feed | Restarting real-time data updates for symbol: CLk24-NYMEX -> CLK24 2024-04-08 16:13:02.391 | Delayed Data Feed | Restarting real-time data updates for symbol: MYMM24-CBOT -> MYMM24 2024-04-08 16:13:02.391 | Delayed Data Feed | Restarting real-time data updates for symbol: ZBM24-CBOT -> ZBM24 2024-04-08 16:13:02.457 | Denali Data Feed | Received logon response. 2024-04-08 16:13:02.457 | Denali Data Feed | Server Name: SC Realtime Server. 2024-04-08 16:13:02.457 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-04-08 16:13:02.457 | Denali Data Feed | Successfully connected. 2024-04-08 16:13:02.457 | Denali Data Feed | Trading is not supported. 2024-04-08 16:13:02.457 | Denali Data Feed | MarketDepthIsSupported: 1 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: AAPL -> AAPL 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: ACB -> ACB 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: ADBE -> ADBE 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: ALAB -> ALAB 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: AMGN -> AMGN 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: AMZN -> AMZN 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: ARM -> ARM 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: AVGO -> AVGO 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: BA -> BA 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: BITO -> BITO 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: BITX -> BITX 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: CAT -> CAT 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: CGC -> CGC 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: CLSK -> CLSK 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: COIN -> COIN 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: CONL -> CONL 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: COST -> COST 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: CSCO -> CSCO 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: DIA -> DIA 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: DJT -> DJT 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: DNUT -> DNUT 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: DXYZ -> DXYZ 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: FBTC -> FBTC 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: GOOGL -> GOOGL 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: GS -> GS 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: HD -> HD 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: IBIT -> IBIT 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: IWM -> IWM 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: LIN -> LIN 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: MARA -> MARA 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: MCD -> MCD 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: META -> META 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: MSFT -> MSFT 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: MSTR -> MSTR 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: MU -> MU 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: NFLX -> NFLX 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: NVDA -> NVDA 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: PEP -> PEP 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: PLTR -> PLTR 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: QCOM -> QCOM 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: QQQ -> QQQ 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: RDDT -> RDDT 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: RIOT -> RIOT 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: SLV -> SLV 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: SMCI -> SMCI 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: SMH -> SMH 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: SOUN -> SOUN 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: SOXL -> SOXL 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: SOXS -> SOXS 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: SPY -> SPY 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: TLT -> TLT 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: TSLA -> TSLA 2024-04-08 16:13:02.457 | Denali Data Feed | Restarting real-time data updates for symbol: UNH -> UNH 2024-04-08 16:13:02.458 | Denali Data Feed | Restarting real-time data updates for symbol: V -> V 2024-04-08 16:13:02.458 | Denali Data Feed | Restarting real-time data updates for symbol: VKTX -> VKTX 2024-04-08 16:13:02.458 | Denali Data Feed | Restarting real-time data updates for symbol: VNO -> VNO 2024-04-08 16:13:02.458 | Denali Data Feed | Restarting real-time data updates for symbol: VTYX -> VTYX 2024-04-08 16:13:02.458 | Denali Data Feed | Restarting real-time data updates for symbol: XLC -> XLC 2024-04-08 16:13:02.458 | Denali Data Feed | Restarting real-time data updates for symbol: XLK -> XLK 2024-04-08 16:13:02.458 | Denali Data Feed | Restarting real-time data updates for symbol: XLP -> XLP 2024-04-08 16:13:02.458 | Denali Data Feed | Restarting real-time data updates for symbol: XLU -> XLU 2024-04-08 16:13:02.458 | Denali Data Feed | Restarting real-time data updates for symbol: XLV -> XLV 2024-04-08 16:13:02.458 | Denali Data Feed | Restarting real-time data updates for symbol: XLY -> XLY 2024-04-08 16:13:02.498 | SC Data with Depth | Received logon response. 2024-04-08 16:13:02.498 | SC Data with Depth | Server Name: SC Realtime Server. 2024-04-08 16:13:02.498 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8 2024-04-08 16:13:02.498 | SC Data with Depth | Successfully connected. 2024-04-08 16:13:02.498 | SC Data with Depth | Trading is not supported. 2024-04-08 16:13:02.498 | SC Data with Depth | MarketDepthIsSupported: 1 2024-04-08 16:13:02.498 | SC Data with Depth | Restarting real-time data updates for symbol: ADR-NQ 2024-04-08 16:13:02.498 | SC Data with Depth | Restarting real-time data updates for symbol: ADR-SP 2024-04-08 16:13:02.498 | SC Data with Depth | Restarting real-time data updates for symbol: NVOL24H-NQ 2024-04-08 16:13:02.498 | SC Data with Depth | Restarting real-time data updates for symbol: NVOL24H-NYSE 2024-04-08 16:13:02.498 | SC Data with Depth | Restarting real-time data updates for symbol: TICK-NQ 2024-04-08 16:13:02.498 | SC Data with Depth | Restarting real-time data updates for symbol: TICK-NYSE 2024-04-08 16:13:02.498 | SC Data with Depth | Restarting real-time data updates for symbol: TRIN-NQ 2024-04-08 16:13:02.498 | SC Data with Depth | Restarting real-time data updates for symbol: TRIN-SP 2024-04-08 16:13:02.546 | Denali Data Feed | Received logon response. 2024-04-08 16:13:02.546 | Denali Data Feed | Server Name: SC Realtime Server. 2024-04-08 16:13:02.546 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-04-08 16:13:02.546 | Denali Data Feed | Successfully connected. 2024-04-08 16:13:02.546 | Denali Data Feed | Trading is not supported. 2024-04-08 16:13:02.546 | Denali Data Feed | MarketDepthIsSupported: 1 2024-04-08 16:13:02.546 | Denali Data Feed | Restarting real-time data updates for symbol: ESM24-CME -> ESM24 2024-04-08 16:13:02.546 | Denali Data Feed | Restarting real-time data updates for symbol: MESM24-CME -> MESM24 2024-04-08 16:13:02.546 | Denali Data Feed | Restarting real-time data updates for symbol: MNQM24-CME -> MNQM24 2024-04-08 16:13:02.546 | Denali Data Feed | Restarting real-time data updates for symbol: NQM24-CME -> NQM24 2024-04-08 16:13:02.548 | Delayed Data Feed | Received security definition for symbol CLk24-NYMEX 2024-04-08 16:13:02.548 | Delayed Data Feed | Received security definition for symbol MYMM24-CBOT 2024-04-08 16:13:02.548 | Delayed Data Feed | Received security definition for symbol ZBM24-CBOT 2024-04-08 16:13:02.606 | Denali Data Feed | Received security definition for symbol AAPL 2024-04-08 16:13:02.606 | Denali Data Feed | Received security definition for symbol ACB 2024-04-08 16:13:02.607 | Denali Data Feed | Received security definition for symbol ADBE 2024-04-08 16:13:02.607 | Denali Data Feed | Received security definition for symbol ALAB 2024-04-08 16:13:02.607 | Denali Data Feed | Received security definition for symbol AMGN 2024-04-08 16:13:02.607 | Denali Data Feed | Received security definition for symbol AMZN 2024-04-08 16:13:02.607 | Denali Data Feed | Received security definition for symbol ARM 2024-04-08 16:13:02.607 | Denali Data Feed | Received security definition for symbol AVGO 2024-04-08 16:13:02.607 | Denali Data Feed | Received security definition for symbol BA 2024-04-08 16:13:02.607 | Denali Data Feed | Received security definition for symbol BITO 2024-04-08 16:13:02.607 | Denali Data Feed | Received security definition for symbol BITX 2024-04-08 16:13:02.608 | Denali Data Feed | Received security definition for symbol CAT 2024-04-08 16:13:02.608 | Denali Data Feed | Received security definition for symbol CGC 2024-04-08 16:13:02.608 | Denali Data Feed | Received security definition for symbol CLSK 2024-04-08 16:13:02.608 | Denali Data Feed | Received security definition for symbol COIN 2024-04-08 16:13:02.608 | Denali Data Feed | Received security definition for symbol CONL 2024-04-08 16:13:02.608 | Denali Data Feed | Received security definition for symbol COST 2024-04-08 16:13:02.608 | Denali Data Feed | Received security definition for symbol CSCO 2024-04-08 16:13:02.608 | Denali Data Feed | Received security definition for symbol DIA 2024-04-08 16:13:02.608 | Denali Data Feed | Received security definition for symbol DJT 2024-04-08 16:13:02.608 | Denali Data Feed | Received security definition for symbol DNUT 2024-04-08 16:13:02.608 | Denali Data Feed | Received security definition for symbol DXYZ 2024-04-08 16:13:02.608 | Denali Data Feed | Received security definition for symbol FBTC 2024-04-08 16:13:02.608 | Denali Data Feed | Received security definition for symbol GOOGL 2024-04-08 16:13:02.609 | Denali Data Feed | Received security definition for symbol GS 2024-04-08 16:13:02.609 | Denali Data Feed | Received security definition for symbol HD 2024-04-08 16:13:02.609 | Denali Data Feed | Received security definition for symbol IBIT 2024-04-08 16:13:02.609 | Denali Data Feed | Received security definition for symbol IWM 2024-04-08 16:13:02.609 | Denali Data Feed | Received security definition for symbol LIN 2024-04-08 16:13:02.609 | Denali Data Feed | Received security definition for symbol MARA 2024-04-08 16:13:02.609 | Denali Data Feed | Received security definition for symbol MCD 2024-04-08 16:13:02.609 | Denali Data Feed | Received security definition for symbol META 2024-04-08 16:13:02.609 | Denali Data Feed | Received security definition for symbol MSFT 2024-04-08 16:13:02.609 | Denali Data Feed | Received security definition for symbol MSTR 2024-04-08 16:13:02.609 | Denali Data Feed | Received security definition for symbol MU 2024-04-08 16:13:02.609 | Denali Data Feed | Received security definition for symbol NFLX 2024-04-08 16:13:02.610 | Denali Data Feed | Received security definition for symbol NVDA 2024-04-08 16:13:02.610 | Denali Data Feed | Received security definition for symbol PEP 2024-04-08 16:13:02.610 | Denali Data Feed | Received security definition for symbol PLTR 2024-04-08 16:13:02.610 | Denali Data Feed | Received security definition for symbol QCOM 2024-04-08 16:13:02.610 | Denali Data Feed | Received security definition for symbol QQQ 2024-04-08 16:13:02.610 | Denali Data Feed | Received security definition for symbol RDDT 2024-04-08 16:13:02.610 | Denali Data Feed | Received security definition for symbol RIOT 2024-04-08 16:13:02.610 | Denali Data Feed | Received security definition for symbol SLV 2024-04-08 16:13:02.610 | Denali Data Feed | Received security definition for symbol SMCI 2024-04-08 16:13:02.654 | SC Data with Depth | Received security definition for symbol ADR-NQ 2024-04-08 16:13:02.654 | SC Data with Depth | Received security definition for symbol ADR-SP 2024-04-08 16:13:02.654 | SC Data with Depth | Received security definition for symbol NVOL24H-NQ 2024-04-08 16:13:02.654 | SC Data with Depth | Received security definition for symbol NVOL24H-NYSE 2024-04-08 16:13:02.654 | SC Data with Depth | Received security definition for symbol TICK-NQ 2024-04-08 16:13:02.655 | SC Data with Depth | Received security definition for symbol TICK-NYSE 2024-04-08 16:13:02.655 | SC Data with Depth | Received security definition for symbol TRIN-NQ 2024-04-08 16:13:02.655 | SC Data with Depth | Received security definition for symbol TRIN-SP 2024-04-08 16:13:02.699 | Denali Data Feed | Received security definition for symbol SMH 2024-04-08 16:13:02.699 | Denali Data Feed | Received security definition for symbol SOUN 2024-04-08 16:13:02.699 | Denali Data Feed | Received security definition for symbol SOXL 2024-04-08 16:13:02.699 | Denali Data Feed | Received security definition for symbol SOXS 2024-04-08 16:13:02.699 | Denali Data Feed | Received security definition for symbol SPY 2024-04-08 16:13:02.700 | Denali Data Feed | Received security definition for symbol TLT 2024-04-08 16:13:02.700 | Denali Data Feed | Received security definition for symbol TSLA 2024-04-08 16:13:02.700 | Denali Data Feed | Received security definition for symbol UNH 2024-04-08 16:13:02.700 | Denali Data Feed | Received security definition for symbol V 2024-04-08 16:13:02.700 | Denali Data Feed | Received security definition for symbol VKTX 2024-04-08 16:13:02.700 | Denali Data Feed | Received security definition for symbol VNO 2024-04-08 16:13:02.700 | Denali Data Feed | Received security definition for symbol VTYX 2024-04-08 16:13:02.700 | Denali Data Feed | Received security definition for symbol XLC 2024-04-08 16:13:02.700 | Denali Data Feed | Received security definition for symbol XLK 2024-04-08 16:13:02.700 | Denali Data Feed | Received security definition for symbol XLP 2024-04-08 16:13:02.700 | Denali Data Feed | Received security definition for symbol XLU 2024-04-08 16:13:02.700 | Denali Data Feed | Received security definition for symbol XLV 2024-04-08 16:13:02.701 | Denali Data Feed | Received security definition for symbol XLY 2024-04-08 16:13:02.704 | Denali Data Feed | Received security definition for symbol ESM24-CME 2024-04-08 16:13:02.704 | Denali Data Feed | Received security definition for symbol MESM24-CME 2024-04-08 16:13:02.705 | Denali Data Feed | Received security definition for symbol MNQM24-CME 2024-04-08 16:13:02.705 | Denali Data Feed | Received security definition for symbol NQM24-CME 2024-04-08 16:13:06.489 | Requesting market depth updates for: AMD if supported. NumLevels=100 2024-04-08 16:13:06.489 | Separate subscription for market depth updates not supported. AMD 2024-04-08 16:13:06.621 | HD Request # 116 | Downloading Intraday chart data for AMD to the file AMD.scid. Service: scdataallservices 2024-04-08 16:13:06.622 | HD Request # 116 | Download start date-time: 2024-04-08 13:44:00.000000. File last date-time: 2024-04-08 13:44:00.000000 2024-04-08 16:13:06.969 | HD Request # 116 | Requesting historical Intraday Minute data for AMD starting at 2024-04-08 16:44:00 (Exchange time). 2024-04-08 16:13:07.253 | HD Request # 116 | Receiving Intraday data for AMD starting at 2024-04-08 13:44:00.000000 2024-04-08 16:13:07.253 | HD Request # 116 | Bytes received: 58 2024-04-08 16:13:07.253 | HD Request # 116 | Received 1 Intraday data record from 2024-04-08 13:44:00.000000 to 2024-04-08 13:44:00.000000 (0.0 seconds. Delay: 2.5 hours) and wrote 0 records for AMD 2024-04-08 16:13:07.254 | HD Request # 116 | Add time&sales data | Remembered last file record date-time: 2024-04-08 20:44:00.000000 2024-04-08 16:13:07.254 | HD Request # 116 | Completion time: 1s. 2024-04-08 16:13:07.254 | HD Request # 116 | Intraday data download complete for AMD. Unique request ID: 138 2024-04-08 16:13:07.255 | Removing historical data download ID 138. 2024-04-08 16:13:07.255 | Real-time Intraday chart data file updates started for AMD 2024-04-08 16:13:07.255 | Intraday chart data file opened for AMD 2024-04-08 16:13:07.255 | HD Request # 116 | Enabling Intraday chart updating for symbol. 2024-04-08 16:13:07.255 | 2024-04-08 16:13:07.255 | No download requests in the queue to start downloads for. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-09 15:35:27] |
John - SC Support - Posts: 31240 |
We see the following in your log: 2024-04-08 16:13:01.746 | SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: AMD
Please update Symbol Settings by following these instructions: Global Symbol Settings: Update Symbol Settings And then turn off the use of Custom Symbol Settings by deselecting the option at the top of the Symbol Settings window. Refer to the following: Global Symbol Settings: Use Custom Symbol Settings Values (Global Settings >> Symbol Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
