Date/Time: Wed, 01 May 2024 10:02:46 +0000
ZT Initial Balance Lines are missing
View Count: 74
[2024-04-08 20:49:56] |
ted chuang - Posts: 11 |
Dear SC engineers, The ZT chart's IBL just won't show after the IB are added under studies settings. The IB type is set as daily. The start/end time would be 820am-:29:590am EST. What else can be checked? Thank you. |
[2024-04-08 20:50:35] |
John - SC Support - Posts: 31240 |
Exactly which study are you using?
[2024-04-08 21:53:20] |
Please take a look if I have fixed it already? I'm still not 100% sure. These chart books were provided by my trading mentor n he didn't tell me the way how he did it. It seemed to me my mentor did it via study/overlay functions, idk? I followed the SC's instructions. Please advise otherwise. Next, how'd I thicken the IBH/IBL white lines. I can't do that via IB settings??? Thanks again. |
ZT IB Issues.png / V - Attached On 2024-04-08 21:52:15 UTC - Size: 1.81 MB - 15 views |
[2024-04-08 22:55:39] |
The "Initial Balance" study makes sense for that chart. So that should be fine. You change the color, line style, and/or line thickness through the Subgraphs, which are the data holders. This is on the "Subgraphs" tab of the Initial Balance Settings window. Refer to the following: Chart Studies: Subgraphs Tab For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
