Date/Time: Wed, 01 May 2024 02:46:02 +0000
Calculating Swing High/Low Point Differential?
View Count: 120
[2024-04-08 19:09:23] |
FXutures - Posts: 2 |
Is there an indicator/way that's already established to display the point differential of Swing High/Low Points? Currently using swing points calculated every 1 bar. Trying to determine which sized Swing Points provide best the breakouts/reversals. If not already possible, how would I go about coding this to a custom study? I added a screenshot of the swing points I am referring too Arrow up and down.
Date Time Of Last Edit: 2024-04-08 19:10:45
Screenshot 2024-04-08 at 3.01.03 PM.png / V - Attached On 2024-04-08 19:06:26 UTC - Size: 320.6 KB - 34 views |
[2024-04-08 19:31:06] |
John - SC Support - Posts: 31240 |
There is not something that does exactly what you want. But you should be able to use the Spreadsheet Study to be able to determine what you want. Keep in mind that the study information is put in the Spreadsheet Study starting at column AA by default.
