Date/Time: Wed, 01 May 2024 00:17:46 +0000
Equivalent Momentum Indicator in Sierra Chart
View Count: 73
[2024-04-08 18:44:32] |
User951086 - Posts: 12 |
I frequently utilize the built-in Momentum Indicator on TradingView. Recently, I've been searching for a comparable version of this indicator within Sierra Chart. I assume that since it's a built-in indicator on TradingView, it should most likely be available on Sierra Chart as well, given the universal nature of the formula used in that indicator. Does anyone know under what name it is listed in Sierra Chart? This information can be crucial for anyone, as it will enable them to automate some of the entries using the Spreadsheet System for Trading tool. |
TradingView Momentum Indicator.png / V - Attached On 2024-04-08 18:44:17 UTC - Size: 104.15 KB - 27 views |
[2024-04-08 19:23:32] |
John - SC Support - Posts: 31240 |
We have a number of studies with the word "Momentum" in the title. You can search the names of all studies we have available at the following link: Technical Studies Reference Then go into any one of them to view the information, including the math that we use, for any particular study. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
