Date/Time: Wed, 01 May 2024 08:03:31 +0000
Centering charts with NO DOM?
View Count: 87
[2024-04-08 15:04:16] |
TopGunTrader - Posts: 136 |
Hi, I setup today many of the biggest stocks next to ES and NQ and put DOM's on them so my hotkey to center did it for the stocks to really helped my trading but don't want to see the DOM on the stocks. I posted this question 6 months ago and it was never answered, is there a way to when DOM hotkey is pressed to center for other non DOM charts to be centered too? I want to see many stocks and the DOM takes up too much space. Getting rid of the buy/sell columns would work for me as well and that isn't allowed now. |
[2024-04-08 17:18:11] |
John - SC Support - Posts: 31240 |
We are not understanding what it is exactly that you want to do. What keyboard Shortcut are you using and what do you want (or not want) to have occur? With regards to the Buy/Sell columns, you can hide these on a Chart, but not on a Trading DOM. On a Chart just turn off the options for "Trading Chart DOM On" and/or "Show Market Data Columns". For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-08 17:55:18] |
I set the W key to recenter chart and trading DOM's. I want some stock charts to recenter too so they are all lined up and I can easily see after each reset if say MSFT and AAPL are going up/down. It seems I have to add the DOM to them for this and it takes up too much space. I've attached a pic would love to get rid of the space on right of each chart so I can have more up or see more back history. The red X areas would love to get rid of. Or if possible not have DOM on charts and have them recenter when I recenter ES DOM which hotkey resets all DOM's. |
Capture.PNG / V - Attached On 2024-04-08 17:53:28 UTC - Size: 357.99 KB - 24 views |
[2024-04-08 19:19:02] |
There is a Keyboard Shortcut option for "Reset Scales - All Charts". This will reset the scales for all the charts including Trading DOMs. If you do not want the price ladder displayed, refer to the following option: Chart Settings: Hide Values Scale (Chart >> Chart Settings >> Scale menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-09 12:36:10] |
That worked like a charm had no idea that feature existed thank you!
