Date/Time: Thu, 02 May 2024 06:10:52 +0000
UDP Interface
View Count: 97
[2024-04-08 14:08:41] |
User907968 - Posts: 802 |
Hello, I just updated from v2568 to v2627 and UDP interface seems broken. For example, when sending OPEN_CHARTBOOK-- message, the result is an attempt to open a chart with symbol OPEN_CHARTBOOK--, rather than opening the chartbook requested. What happened? This is a pain, as that command is (was) used to synchronize opening/switching chartbooks across multiple instances. Date Time Of Last Edit: 2024-04-08 14:10:20
[2024-04-08 14:21:18] |
Sierra_Chart Engineering - Posts: 14173 |
That command is no longer supported with UDP. Use ACSIL instead. It can open Chartbooks. Refer to: sc.OpenChartbook() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-08 14:36:57] |
Ok. I will stay on 2568 for now and work out an alternative solution. |
