Date/Time: Mon, 25 Nov 2024 02:04:40 +0000
Enable Order Allocation To Trade Accounts - On-Startup
View Count: 213
[2024-04-08 13:38:28]
User92573 - Posts: 530
Dear Support
Is there a way to "Enable Order Allocation To Trade Accounts - On-Startup?"
Once again lost money as not enabled and only demo connected. Must be a default just cannot find it.
Many thanks.
[2024-04-08 16:07:28]
Refer to the following setting:
Global Trade Settings Windows: Disable Order Allocation To Trade Accounts on Chartbook Opening (Global Settings >> General Trade Settings >> General)
If you do not have this option, then you would need to update to the current release by following these instructions:
[2024-04-08 17:22:22]
Great John,
Many thanks.
