Date/Time: Thu, 02 May 2024 01:49:04 +0000
vertical line from time in spreadsheet column
View Count: 74
[2024-04-07 11:27:49] |
User12089 - Posts: 350 |
a column in a spreadsheet contains valid date/time value in SC format - it is used correctly in e.g. other study alert formulas etc the date/time is the same in any cell of that column ie it is constant question - is there any way to produce a vertical line on the chart anchored at the constant date/time value in the spreadsheet study column |
[2024-04-08 15:28:49] |
John - SC Support - Posts: 31293 |
There is not a built-in way to do this. You would have to create a custom study to do this. Refer to the following: sc.GetSheetCellAsDouble() List of Third Party Sierra Chart Study and System Programmers For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
