Date/Time: Thu, 02 May 2024 08:35:44 +0000
Clock
View Count: 137
[2024-04-06 22:27:53] |
User14953 - Posts: 191 |
For your consideration, we request a setting for the clock display showing only minutes and seconds (mm:ss) without hour digits. This adjustment would optimize the use of screen space on the critical right edge, enhancing the user experience. Clock - RealTime
[2024-04-07 03:37:26] |
Sierra_Chart Engineering - Posts: 14173 |
You can easily modify that study to meet your requirements. Refer to: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-07 15:33:22] |
gcUserStudies - Posts: 91 |
Hello. Please try this. It's just modified version of the existing study to add an option to Display Hour or not. |
gcClock.cpp - Attached On 2024-04-07 15:31:44 UTC - Size: 3.94 KB - 42 views Private File |
