Date/Time: Thu, 02 May 2024 12:12:32 +0000
DOM Replay Depth Synchronization
View Count: 86
[2024-04-06 21:38:20] |
Gradient - Posts: 41 |
Hi, I'm replaying a chart and DOM. The chart and the DOM are synced. However, I noticed that while the price on the DOM and the Chart match, the actual depth on the book and the price on the book are out of sync. (see attachment) Why might this be happening? How can I resolve this? Thanks |
DOM Depth Price Replay Not Synced.png / V - Attached On 2024-04-06 21:37:53 UTC - Size: 40.69 KB - 33 views |
[2024-04-06 22:24:47] |
Sierra_Chart Engineering - Posts: 14175 |
Does that consistently occur? Perhaps there is a point at which, there is no longer any historical market depth data at the point in time of the replay.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-04-06 22:25:22
