Date/Time: Thu, 02 May 2024 05:04:45 +0000
Spread sheet help please
View Count: 87
[2024-04-06 18:36:37] |
User411320 - Posts: 263 |
so I'm trying to input a simple formula =(C3+D3/2)-(C4+D4/2) and when I press enter it calculates correctly. The issue I'm having is when I go to the chart and I select in the study, it automatically deletes. what can be the issue?
[2024-04-08 14:55:02] |
John - SC Support - Posts: 31293 |
We are not understanding the situation you are trying to describe. What do you mean by "when I go to the chart and I select in the study, it automatically deletes."? What are you selecting and what is getting deleted? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
