Date/Time: Fri, 18 Sep 2026 10:00:51 +0000
[User Discussion] - Data not displayed during replay
View Count: 605
| [2024-04-06 17:27:11] |
| masedi - Posts: 63 |
During regular trading the buy and sell columns are populated with the volumes, however when doing a replay these vales are not displayed. I followed the instructions mentioned in several other threads with no luck. The files are present in the market depth folder and the log shows that the files are loaded before starting the replay. (screenshot attached). Even though I don`t think it is related since I am using denali data, I tried using SC_DATA and also tried with my RITHMIC account in the data/trade settings and both give the same result. Can you please guide me on how to resolve this or how to figure out what is going wrong? I didn`t have this issue before. Thanks |
| [2024-04-07 14:25:26] |
I found the issue ... In the chart settings -> data limiting the number of days is not applicable to market depth data days to load. There is a separate setting under chart setting -> market depth which specifies that. I don't remember changing this parameter before and it was only 0 in the DOM chart. Date Time Of Last Edit: 2024-04-07 14:49:07
