Date/Time: Fri, 10 May 2024 11:53:44 +0000
Volume overlay upon contract count information
View Count: 104
[2024-04-05 15:37:19] |
User577837 - Posts: 3 |
Hello, This fix may be in front of my eyes, but I can't locate it. I am trying to delete a volume overlay upon the contract count column. I have no idea how I placed it on there to begin with. That said, I do like it but it interferes with my ability to seed the contract accumulation (please see attached). Would you be able to point me in the direction of how to delete this, and could you please let me know what this overlay is called as I may want to revisit it in the future. Thank you-much appreciate your time. |
Capture.PNG / V - Attached On 2024-04-05 15:35:41 UTC - Size: 6.38 KB - 24 views Attachment Deleted. |
[2024-04-05 15:45:12] |
John - SC Support - Posts: 31509 |
We are a bit confused by your image, as it appears to be a standard Volume by Price profile, but the volumes should be drawn above the bars. If the above is correct and you want to remove the display of the bars, then go to the "Volume by Price" study that is drawing that and set the Input for "Volume Bars Draw Method" to "Blank". Refer to the following: Volume By Price Study: Volume Bars Draw Method If the above does not solve this for you, then we would need to see an image of your full chart by following these instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-05 20:33:31] |
Thanks. I was able to go in an delete it.
