Date/Time: Thu, 02 May 2024 07:23:26 +0000
Candle generated delayed for CME
View Count: 232
[2024-04-05 14:15:08] |
FinalDevil - Posts: 7 |
As I observed whenever candle generated, I check the timestamp of that candle and check the realtime clock study, it always delayed from 10s or more. From this it should be fixed now but seem still not yet. Notice: Delayed Streaming CME Data Issue |
[2024-04-05 14:23:06] |
Sierra_Chart Engineering - Posts: 14173 |
Tell us the exact symbol of the chart. Also refer to: Prices / Data Falling Behind That thread is unrelated to your issue. That refers to delayed streaming data. You have real-time data for CME. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-04-05 14:23:28
[2024-04-06 01:53:54] |
Symbol is NQM24_FUT_CME To be precise, I realize that when velocity increase, the delay increase, and it will drop to about 2-5s on normal pace. Most of the time, the first 30min always go delayed when render candles. I have tested running 1 single chartbook, only 1 chart in that chartbook, set display refresh rate to 200ms, no any study, the issue still happen. |
[2024-04-06 14:34:48] |
If you are noticing a delay, with data, go through the information here: Prices / Data Falling Behind Make sure your computer's clock is set accurately. Refer to: Network Time Protocol Client Make sure you are running the current version of Sierra Chart: Software Download: Fast Update Also provide heartbeat messages at the time of the delay so we can see what is happening: Prices / Data Falling Behind: 4.17 - Providing Heartbeat Messages to Sierra Chart Support Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-04-06 14:35:35
[2024-04-08 13:33:04] |
Let's say candle current price line is printing at 18310, if I place a buy limit order at 18300, the order filled immediately at 18300 with some profit/loss points of the realtime data (while candle not printed yet), and several seconds later, the candle prints at 18300. Below is heartbeat. 2024-04-08 21:30:01.189 | Software version: 2627 64-bit
2024-04-08 21:30:01.189 | OpenGL enabled (NVIDIA Corporation/NVIDIA GeForce RTX 3070/PCIe/SSE2) 2024-04-08 21:30:01.189 | Primary Thread ID: 5020 2024-04-08 21:30:01.189 | Usage end date: 2024-10-05 2024-04-08 21:30:01.189 | Enabled for: Advanced Features 2. 2024-04-08 21:30:01.189 | Enabled for: Sierra Chart Historical Data Service. 2024-04-08 21:30:01.189 | Enabled for: Denali Real-Time Exchange Data Feed. 2024-04-08 21:30:01.189 | Enabled for: Delayed Denali Exchange Data Feed. 2024-04-08 21:30:01.189 | Enabled for exchange2: CME 2024-04-08 21:30:01.189 | Allow Support for Sierra Chart Data Feeds is enabled. 2024-04-08 21:30:01.189 | Current selected Data/Trading service: Teton CME Order Routing 2024-04-08 21:30:01.189 | Custom symbol settings values: enabled 2024-04-08 21:30:01.189 | Chart Update Interval: 500 2024-04-08 21:30:01.189 | Intraday Data Storage Time Unit: 0 2024-04-08 21:30:01.189 | Time Zone: +08:00:00 (HKT+08) 2024-04-08 21:30:01.189 | 2024-04-08 13:30:01 Local computer time in UTC 2024-04-08 21:30:01.189 | 2024-04-08 21:30:01 Local computer time in SC Time Zone 2024-04-08 21:30:01.189 | 2024-04-08 11:54:09 Server time in UTC 2024-04-08 21:30:01.189 | Local computer UTC time and Server UTC time difference: 2 seconds. 2024-04-08 21:30:01.189 | Program path: D:\SierraChart\ 2024-04-08 21:30:01.189 | Data Files path: D:\SierraChart\Data\ 2024-04-08 21:30:01.190 | OS Version Number: 10.0 2024-04-08 21:30:01.190 | Locale Setting: C 2024-04-08 21:30:01.190 | DLLs: FDStudies2_64.dll, gcUserStudies_2499_64.dll, pace_of_tape_64.dll, ProfitsLossStudyV22_64.dll, ProfitsLossStudy_64.dll, pullstackstudyV2_64.dll, pullstack_64.dll, UserContributedStudies_64.dll 2024-04-08 21:30:01.190 | Allowed protected custom studies: FinalDevil Studies Suite, zyp_app 2024-04-08 21:30:01.190 | Crash reporter started: true 2024-04-08 21:30:01.190 | 2024-04-08 21:30:03.203 | Teton CME Order Routing | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=18, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.0 seconds, DataCompRatio=0.00, UncompressedBytes=101168, CompressionTime=0.000000(secs), NumCompressions=0, Source=208.185.224.130 2024-04-08 21:30:09.030 | Denali Data Feed | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=15, NumberOfOutstandingSendBuffers=9, TransmissionDelayInMilliseconds=305, ServerSendBufferSizeInBytes=92192, ActualMessageDelay=4.1 seconds, DataCompRatio=3.39, UncompressedBytes=34093793, CompressionTime=0.305823(secs), NumCompressions=27039, Source=10.10.20.123, MaxSendBufferSize=105809, MaxSendBufferSizeDateTime=2024-04-08 13:30:01 2024-04-08 21:30:13.207 | Teton CME Order Routing | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=8, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.0 seconds, DataCompRatio=0.00, UncompressedBytes=101271, CompressionTime=0.000000(secs), NumCompressions=0, Source=208.185.224.130 2024-04-08 21:30:23.207 | Teton CME Order Routing | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=18, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.0 seconds, DataCompRatio=0.00, UncompressedBytes=101374, CompressionTime=0.000000(secs), NumCompressions=0, Source=208.185.224.130 2024-04-08 21:30:33.200 | Teton CME Order Routing | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=8, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.0 seconds, DataCompRatio=0.00, UncompressedBytes=101477, CompressionTime=0.000000(secs), NumCompressions=0, Source=208.185.224.130 2024-04-08 21:30:37.742 | Denali Data Feed | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=14, NumberOfOutstandingSendBuffers=12, TransmissionDelayInMilliseconds=380, ServerSendBufferSizeInBytes=168468, ActualMessageDelay=12.7 seconds, DataCompRatio=3.40, UncompressedBytes=36054414, CompressionTime=0.313039(secs), NumCompressions=27087, Source=10.10.20.123, MaxSendBufferSize=220535, MaxSendBufferSizeDateTime=2024-04-08 13:30:24 2024-04-08 21:30:43.198 | Teton CME Order Routing | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=18, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.0 seconds, DataCompRatio=0.00, UncompressedBytes=101580, CompressionTime=0.000000(secs), NumCompressions=0, Source=208.185.224.130 2024-04-08 21:30:53.210 | Teton CME Order Routing | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=7, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.0 seconds, DataCompRatio=0.00, UncompressedBytes=101683, CompressionTime=0.000000(secs), NumCompressions=0, Source=208.185.224.130 2024-04-08 21:31:03.210 | Teton CME Order Routing | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=17, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.0 seconds, DataCompRatio=0.00, UncompressedBytes=101786, CompressionTime=0.000000(secs), NumCompressions=0, Source=208.185.224.130 2024-04-08 21:31:08.930 | Denali Data Feed | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=14, NumberOfOutstandingSendBuffers=25, TransmissionDelayInMilliseconds=705, ServerSendBufferSizeInBytes=463791, ActualMessageDelay=23.9 seconds, DataCompRatio=3.42, UncompressedBytes=38272694, CompressionTime=0.320450(secs), NumCompressions=27120, Source=10.10.20.123, MaxSendBufferSize=523898, MaxSendBufferSizeDateTime=2024-04-08 13:30:42 2024-04-08 21:31:13.198 | Teton CME Order Routing | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=7, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.0 seconds, DataCompRatio=0.00, UncompressedBytes=101889, CompressionTime=0.000000(secs), NumCompressions=0, Source=208.185.224.130 2024-04-08 21:31:23.201 | Teton CME Order Routing | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=17, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.0 seconds, DataCompRatio=0.00, UncompressedBytes=101992, CompressionTime=0.000000(secs), NumCompressions=0, Source=208.185.224.130 2024-04-08 21:31:25.915 | NQM24_FUT_CME/MNQM24_FUT_CME [CV][M] 750 Volume #8 | Reloading chart. 2024-04-08 21:31:26.244 | NQM24_FUT_CME/MNQM24_FUT_CME [CV][M] 750 Volume #8 | StartDateTimeForLoadingOrderFills: 2024-03-25 09:30:59 2024-04-08 21:31:26.278 | NQM24_FUT_CME/MNQM24_FUT_CME [CV][M] 750 Volume #8 | Chart data loading complete. 2024-04-08 21:31:33.201 | Teton CME Order Routing | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=6, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.1 seconds, DataCompRatio=0.00, UncompressedBytes=102095, CompressionTime=0.000000(secs), NumCompressions=0, Source=208.185.224.130 2024-04-08 21:31:33.376 | Denali Data Feed | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=13, NumberOfOutstandingSendBuffers=29, TransmissionDelayInMilliseconds=805, ServerSendBufferSizeInBytes=591501, ActualMessageDelay=28.4 seconds, DataCompRatio=3.45, UncompressedBytes=40254869, CompressionTime=0.327058(secs), NumCompressions=27145, Source=10.10.20.123, MaxSendBufferSize=641298, MaxSendBufferSizeDateTime=2024-04-08 13:31:01 2024-04-08 21:31:43.200 | Teton CME Order Routing | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=16, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.1 seconds, DataCompRatio=0.00, UncompressedBytes=102198, CompressionTime=0.000000(secs), NumCompressions=0, Source=208.185.224.130 2024-04-08 21:31:46.422 | NQM24_FUT_CME/MNQM24_FUT_CME [CV][M] 750 Volume #8 | Reloading chart. 2024-04-08 21:31:46.749 | NQM24_FUT_CME/MNQM24_FUT_CME [CV][M] 750 Volume #8 | StartDateTimeForLoadingOrderFills: 2024-03-25 09:31:14 2024-04-08 21:31:46.782 | NQM24_FUT_CME/MNQM24_FUT_CME [CV][M] 750 Volume #8 | Chart data loading complete. 2024-04-08 21:31:53.202 | Teton CME Order Routing | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=6, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.1 seconds, DataCompRatio=0.00, UncompressedBytes=102301, CompressionTime=0.000000(secs), NumCompressions=0, Source=208.185.224.130 2024-04-08 21:31:59.075 | Denali Data Feed | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=13, NumberOfOutstandingSendBuffers=30, TransmissionDelayInMilliseconds=830, ServerSendBufferSizeInBytes=703364, ActualMessageDelay=34.1 seconds, DataCompRatio=3.48, UncompressedBytes=42301660, CompressionTime=0.333931(secs), NumCompressions=27168, Source=10.10.20.123, MaxSendBufferSize=758004, MaxSendBufferSizeDateTime=2024-04-08 13:31:22 2024-04-08 21:32:03.200 | Teton CME Order Routing | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=16, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.1 seconds, DataCompRatio=0.00, UncompressedBytes=102404, CompressionTime=0.000000(secs), NumCompressions=0, Source=208.185.224.130 2024-04-08 21:32:13.217 | Teton CME Order Routing | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=6, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.1 seconds, DataCompRatio=0.00, UncompressedBytes=102507, CompressionTime=0.000000(secs), NumCompressions=0, Source=208.185.224.130 2024-04-08 21:32:18.688 | Denali Data Feed | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=12, NumberOfOutstandingSendBuffers=34, TransmissionDelayInMilliseconds=930, ServerSendBufferSizeInBytes=861639, ActualMessageDelay=33.6 seconds, DataCompRatio=3.50, UncompressedBytes=44423636, CompressionTime=0.341441(secs), NumCompressions=27189, Source=10.10.20.123, MaxSendBufferSize=938220, MaxSendBufferSizeDateTime=2024-04-08 13:31:40 2024-04-08 21:32:23.213 | Teton CME Order Routing | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=16, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.1 seconds, DataCompRatio=0.00, UncompressedBytes=102610, CompressionTime=0.000000(secs), NumCompressions=0, Source=208.185.224.130 2024-04-08 21:32:33.244 | Teton CME Order Routing | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=6, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.1 seconds, DataCompRatio=0.00, UncompressedBytes=102713, CompressionTime=0.000000(secs), NumCompressions=0, Source=208.185.224.130 |
[2024-04-08 13:47:08] |
These show you have serious Internet connectivity issues.
[2024-04-08 14:22:16] |
That's the first minute of the session. Here is log of the 50th minute of session. 2024-04-08 22:20:21.722 | Software version: 2627 64-bit 2024-04-08 22:20:21.723 | OpenGL enabled (NVIDIA Corporation/NVIDIA GeForce RTX 3070/PCIe/SSE2) 2024-04-08 22:20:21.723 | Primary Thread ID: 5548 2024-04-08 22:20:21.723 | Usage end date: 2024-10-05 2024-04-08 22:20:21.723 | Enabled for: Advanced Features 2. 2024-04-08 22:20:21.723 | Enabled for: Sierra Chart Historical Data Service. 2024-04-08 22:20:21.723 | Enabled for: Denali Real-Time Exchange Data Feed. 2024-04-08 22:20:21.723 | Enabled for: Delayed Denali Exchange Data Feed. 2024-04-08 22:20:21.723 | Enabled for exchange2: CME 2024-04-08 22:20:21.723 | Allow Support for Sierra Chart Data Feeds is enabled. 2024-04-08 22:20:21.723 | Current selected Data/Trading service: Teton CME Order Routing 2024-04-08 22:20:21.723 | Custom symbol settings values: enabled 2024-04-08 22:20:21.723 | Chart Update Interval: 500 2024-04-08 22:20:21.723 | Intraday Data Storage Time Unit: 0 2024-04-08 22:20:21.723 | Time Zone: +08:00:00 (HKT+08) 2024-04-08 22:20:21.723 | 2024-04-08 14:20:21 Local computer time in UTC 2024-04-08 22:20:21.723 | 2024-04-08 22:20:21 Local computer time in SC Time Zone 2024-04-08 22:20:21.723 | 2024-04-08 14:10:28 Server time in UTC 2024-04-08 22:20:21.723 | Local computer UTC time and Server UTC time difference: 3 seconds. 2024-04-08 22:20:21.723 | Program path: D:\SierraChart\ 2024-04-08 22:20:21.723 | Data Files path: D:\SierraChart\Data\ 2024-04-08 22:20:21.723 | OS Version Number: 10.0 2024-04-08 22:20:21.723 | Locale Setting: C 2024-04-08 22:20:21.723 | DLLs: FDStudies2_64.dll, gcUserStudies_2499_64.dll, pace_of_tape_64.dll, ProfitsLossStudyV22_64.dll, ProfitsLossStudy_64.dll, pullstackstudyV2_64.dll, pullstack_64.dll, UserContributedStudies_64.dll 2024-04-08 22:20:21.723 | Allowed protected custom studies: FinalDevil Studies Suite, zyp_app 2024-04-08 22:20:21.723 | Crash reporter started: true 2024-04-08 22:20:21.723 | 2024-04-08 22:20:23.839 | Teton CME Order Routing | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=4, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.1 seconds, DataCompRatio=0.00, UncompressedBytes=144443, CompressionTime=0.000000(secs), NumCompressions=0, Source=127.0.0.1 2024-04-08 22:20:27.962 | Denali Data Feed | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=3, NumberOfOutstandingSendBuffers=9, TransmissionDelayInMilliseconds=305, ServerSendBufferSizeInBytes=33062, ActualMessageDelay=2.5 seconds, DataCompRatio=3.91, UncompressedBytes=5128000, CompressionTime=0.024108(secs), NumCompressions=471, Source=10.10.20.123, MaxSendBufferSize=139245, MaxSendBufferSizeDateTime=2024-04-08 14:19:01 2024-04-08 22:20:33.836 | Teton CME Order Routing | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=14, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.2 seconds, DataCompRatio=0.00, UncompressedBytes=144546, CompressionTime=0.000000(secs), NumCompressions=0, Source=127.0.0.1 2024-04-08 22:20:43.851 | Teton CME Order Routing | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=3, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.2 seconds, DataCompRatio=0.00, UncompressedBytes=144649, CompressionTime=0.000000(secs), NumCompressions=0, Source=127.0.0.1 2024-04-08 22:20:45.935 | Denali Data Feed | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=3, NumberOfOutstandingSendBuffers=5, TransmissionDelayInMilliseconds=205, ServerSendBufferSizeInBytes=20010, ActualMessageDelay=0.5 seconds, DataCompRatio=3.92, UncompressedBytes=6117402, CompressionTime=0.028563(secs), NumCompressions=566, Source=10.10.20.123, MaxSendBufferSize=139245, MaxSendBufferSizeDateTime=2024-04-08 14:19:01 2024-04-08 22:20:54.191 | Teton CME Order Routing | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=13, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.5 seconds, DataCompRatio=0.00, UncompressedBytes=144752, CompressionTime=0.000000(secs), NumCompressions=0, Source=127.0.0.1 2024-04-08 22:21:03.845 | Teton CME Order Routing | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=3, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.2 seconds, DataCompRatio=0.00, UncompressedBytes=144855, CompressionTime=0.000000(secs), NumCompressions=0, Source=127.0.0.1 2024-04-08 22:21:06.977 | Denali Data Feed | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=3, NumberOfOutstandingSendBuffers=4, TransmissionDelayInMilliseconds=180, ServerSendBufferSizeInBytes=8782, ActualMessageDelay=1.6 seconds, DataCompRatio=3.91, UncompressedBytes=6996826, CompressionTime=0.032989(secs), NumCompressions=681, Source=10.10.20.123, MaxSendBufferSize=139245, MaxSendBufferSizeDateTime=2024-04-08 14:19:01 2024-04-08 22:21:13.848 | Teton CME Order Routing | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=13, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.2 seconds, DataCompRatio=0.00, UncompressedBytes=144958, CompressionTime=0.000000(secs), NumCompressions=0, Source=127.0.0.1 2024-04-08 22:21:23.845 | Teton CME Order Routing | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=2, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.2 seconds, DataCompRatio=0.00, UncompressedBytes=145061, CompressionTime=0.000000(secs), NumCompressions=0, Source=127.0.0.1 2024-04-08 22:21:26.132 | Denali Data Feed | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=3, NumberOfOutstandingSendBuffers=2, TransmissionDelayInMilliseconds=80, ServerSendBufferSizeInBytes=16215, ActualMessageDelay=0.7 seconds, DataCompRatio=3.92, UncompressedBytes=7705968, CompressionTime=0.036366(secs), NumCompressions=771, Source=10.10.20.123, MaxSendBufferSize=139245, MaxSendBufferSizeDateTime=2024-04-08 14:19:01 2024-04-08 22:21:33.853 | Teton CME Order Routing | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=12, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.2 seconds, DataCompRatio=0.00, UncompressedBytes=145164, CompressionTime=0.000000(secs), NumCompressions=0, Source=127.0.0.1 2024-04-08 22:21:43.862 | Teton CME Order Routing | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=2, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.2 seconds, DataCompRatio=0.00, UncompressedBytes=145267, CompressionTime=0.000000(secs), NumCompressions=0, Source=127.0.0.1 2024-04-08 22:21:46.187 | Denali Data Feed | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=3, NumberOfOutstandingSendBuffers=6, TransmissionDelayInMilliseconds=230, ServerSendBufferSizeInBytes=14710, ActualMessageDelay=0.8 seconds, DataCompRatio=3.92, UncompressedBytes=8434068, CompressionTime=0.039654(secs), NumCompressions=868, Source=10.10.20.123, MaxSendBufferSize=139245, MaxSendBufferSizeDateTime=2024-04-08 14:19:01 2024-04-08 22:21:53.853 | Teton CME Order Routing | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=12, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.2 seconds, DataCompRatio=0.00, UncompressedBytes=145370, CompressionTime=0.000000(secs), NumCompressions=0, Source=127.0.0.1 2024-04-08 22:22:03.835 | Teton CME Order Routing | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=2, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.2 seconds, DataCompRatio=0.00, UncompressedBytes=145473, CompressionTime=0.000000(secs), NumCompressions=0, Source=127.0.0.1 2024-04-08 22:22:06.777 | Denali Data Feed | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=2, NumberOfOutstandingSendBuffers=7, TransmissionDelayInMilliseconds=255, ServerSendBufferSizeInBytes=39758, ActualMessageDelay=1.4 seconds, DataCompRatio=3.92, UncompressedBytes=9359297, CompressionTime=0.043584(secs), NumCompressions=972, Source=10.10.20.123, MaxSendBufferSize=139245, MaxSendBufferSizeDateTime=2024-04-08 14:19:01 2024-04-08 22:22:14.578 | Teton CME Order Routing | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=12, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.9 seconds, DataCompRatio=0.00, UncompressedBytes=145576, CompressionTime=0.000000(secs), NumCompressions=0, Source=127.0.0.1 2024-04-08 22:22:23.852 | Teton CME Order Routing | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=1, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.2 seconds, DataCompRatio=0.00, UncompressedBytes=145679, CompressionTime=0.000000(secs), NumCompressions=0, Source=127.0.0.1 2024-04-08 22:22:26.787 | Denali Data Feed | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=2, NumberOfOutstandingSendBuffers=10, TransmissionDelayInMilliseconds=330, ServerSendBufferSizeInBytes=63242, ActualMessageDelay=1.4 seconds, DataCompRatio=3.92, UncompressedBytes=10426553, CompressionTime=0.048500(secs), NumCompressions=1053, Source=10.10.20.123, MaxSendBufferSize=139245, MaxSendBufferSizeDateTime=2024-04-08 14:19:01 2024-04-08 22:22:33.845 | Teton CME Order Routing | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=11, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.2 seconds, DataCompRatio=0.00, UncompressedBytes=145782, CompressionTime=0.000000(secs), NumCompressions=0, Source=127.0.0.1 2024-04-08 22:22:43.861 | Teton CME Order Routing | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=1, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.2 seconds, DataCompRatio=0.00, UncompressedBytes=145885, CompressionTime=0.000000(secs), NumCompressions=0, Source=127.0.0.1 2024-04-08 22:22:46.754 | Denali Data Feed | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=1, NumberOfOutstandingSendBuffers=9, TransmissionDelayInMilliseconds=305, ServerSendBufferSizeInBytes=21625, ActualMessageDelay=1.3 seconds, DataCompRatio=3.91, UncompressedBytes=11251455, CompressionTime=0.052716(secs), NumCompressions=1155, Source=10.10.20.123, MaxSendBufferSize=139245, MaxSendBufferSizeDateTime=2024-04-08 14:19:01 2024-04-08 22:22:53.863 | Teton CME Order Routing | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=11, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.2 seconds, DataCompRatio=0.00, UncompressedBytes=145988, CompressionTime=0.000000(secs), NumCompressions=0, Source=127.0.0.1 Date Time Of Last Edit: 2024-04-08 14:23:09
[2024-04-08 15:16:37] |
Still a problem. This normally should be 0 or 1: NumberOfOutstandingSendBuffers=9 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-08 15:22:54] |
Well. I'm using 1Gbps internet plan from the top 1 network provider in Singapore. There is not much I can do with the network.
