Date/Time: Fri, 10 May 2024 04:40:05 +0000
Request for User Contribution to Update/Maintain Rithmic Symbol Settings
View Count: 114
[2024-04-05 05:48:43] |
Sierra_Chart Engineering - Posts: 14298 |
The maintenance of Symbol Settings is not an easy task. It is a very detail oriented task when new symbols are added, or when there needs to be changes to existing Symbol Settings. We cannot just simply maintain symbols for a single service, but a whole range of services. It is quite burdensome. The Rithmic Symbol Settings has not been well maintained by us and the decision is that there will no longer be any maintenance for it by us. It is attached here. If you are a Rithmic user and you want access to the new CME group symbols, then you can add those symbols and make any other necessary adjustments to the symbol settings. And then submit the changes back to us by uploading the file here. We will review before they are released. This thread is open and can be posted into. It is important to understand that Rithmic like Teton order routing, uses what we call the native price values from the exchange unmodified. Therefore, symbol like ES futures has a Real-time Price Multiplier to adjust the decimal point to the correct position. This is something to be aware of when working on Symbol Settings. CBOT bond futures do not require a multiplier. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-04-05 18:25:11
rithmic_v2.trading.xml - Attached On 2024-04-05 05:46:29 UTC - Size: 193.08 KB - 26 views |
