Date/Time: Thu, 02 May 2024 06:48:56 +0000
saving tool configuration on arrow tool
View Count: 105
[2024-04-04 23:48:41] |
User123891 - Posts: 20 |
This used to be easy for me. I had a small box pop up and I could save the configuration -- I want a wider arrow that is black. I now get skinny green and I cannot figure out how to save the black one instead and put int in Tool Cfg2. The box now is a black box similar to chart settings and I cannot save it. Why change it when the old one was fine? How do you save the drawing now?
[2024-04-05 14:52:13] |
John - SC Support - Posts: 31293 |
The process is exactly the same. Open the Arrow Configuration window and select the Tool Configuration you want to modify. By default, the first 4 are shown on the "Settings" page, so if you want a configuration other than these 4, you need to change to the "SaveConfig" page and select the configuration number you want on that page, then go back to the "Settings" page. Change the settings as you want on the "Settings" page for the Arrow Configuration and then either select the "Apply All" button or go to the "SaveConfig" page and select the "Save" button.
[2024-04-05 22:21:34] |
Sierra_Chart Engineering - Posts: 14173 |
Also be aware of these settings: Chart Drawing Tools: Number of Quick Configurations for First Tab of Chart Drawing Properties (Global Settings >> Tool Settings >> General >> Shortcut Menu and Properties Window) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
