Date/Time: Wed, 27 Nov 2024 06:45:07 +0000
Error in Live Cattle Delta
View Count: 1278
[2014-08-13 13:47:08] |
User80764 - Posts: 10 |
Hi I just updated my platform and the Live Cattle market delta is not working correctly. I have the same set up for hogs and no problem. I use CTS as data provider Please see the attached imagines to chek my set up Thanks Greg |
live_cattle_md.png / V - Attached On 2014-08-13 13:46:50 UTC - Size: 71.08 KB - 372 views live_cattle_md_settings_png.png / V - Attached On 2014-08-13 13:46:54 UTC - Size: 83.78 KB - 368 views |
[2014-08-13 16:34:06] |
Uncheck Global Settings >> Data/Trade Service Settings >> Allow Support for Sierra Chart Data Feeds. Follow the instructions here for a tick by tick data configuration: http://www.sierrachart.com/index.php?page=doc/doc_TickbyTickDataConfiguration.php Doing both of these should resolve the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-13 16:55:27
[2014-08-13 16:38:02] |
The link is not working, wold u mind sending it again thanks greg |
[2014-08-13 16:55:47] |
Here is the correct link: http://www.sierrachart.com/index.php?page=doc/doc_TickbyTickDataConfiguration.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
