Date/Time: Wed, 09 Sep 2026 05:07:11 +0000
[Programming Help] - ACSIL - adding targets for a scale in scale out trade
View Count: 1248
[2024-04-04 21:04:50]
User370774 - Posts: 35
Good Day,
To scale in and out with attached orders I get into the situation that requires to add at least a second target.
Unless I have to somehow add a second "empty" target in the first 1 lot entry that gets later modified and assigned with a quantity.
Either way I'm not sure how to do that. All examples and documentation I find only modify existing attached orders or scale in but not out.
So far I use the s_SCNewOrder structure to create the first entry and then a second s_SCNewOrder to add to that position and then from here I can use the same structure with a sc.ModifyOrder function to change existing oders via their IDs but don't seem to be able to add any.
Could you give some insight? e.g.: 1 lot plus 4 lot, scaling out 4 and leaving 1 runner (with attached orders)
Thank you so much in advance!
WELD
Date Time Of Last Edit: 2024-04-04 21:07:41
[2024-04-12 19:03:28]
Just wanted to let you know the problem is still current.
If you could let me know whether or not there is a way or even have code sample for me to look at I would be most grateful!
Thank you in advance!
