Date/Time: Tue, 14 May 2024 02:15:24 +0000
Regarding the data receiving service.
View Count: 75
[2024-04-04 20:43:03] |
User700604 - Posts: 5 |
Hello, I am a very satisfied user of your service, all is well. I am subscribed to package number 12. I receive data via Denali Exchange Data Feed, very good and complete. I was wondering...If I would also like to use Sierra chart to trade the Asian markets, Hang Seng Future, etc... Not supporting Denali this supply, could I subscribe to another provider? keeping Denali which I am very comfortable with to be able to take advantage only of the Hang Seng Index Future data to be entered into Sierra Chart via my charts. Do you recommend something? Should I give up? I thank you in advance. Best regards. |
[2024-04-04 21:48:24] |
John - SC Support - Posts: 31602 |
You can use Sierra Chart to trade another exchange, such as the HKFE. We just do not have the data or our own connectivity to it. Therefore, you would have to find a broker that supports trading the exchange and that uses either CQG or Rithmic for the order routing to that exchange. They will also have the data for it. Then you would want to install a second Sierra Chart that connects to that service for trading that market. Refer to the following regarding installing a second Sierra Chart: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-04-04 21:48:56
