Date/Time: Tue, 14 May 2024 16:52:44 +0000
Volume Candles (Width Based on Volume)
View Count: 85
[2024-04-04 16:41:48] |
User688525 - Posts: 193 |
Hello Sierra, Is it possible to change the width of a candle based on volume, i.e., large volume candles are wider than regular/average volume candles? If this isn't available out of the box, could it be achieved with a custom study? If this isn't possible, is the "Color Bar Based On Alert Condition" the study to use to color bars based on relative/absolute volume, etc? Thank you |
[2024-04-04 20:14:38] |
John - SC Support - Posts: 31608 |
It is directly available as a Graph Draw Type named "Price Volume Bars". Refer to the following: Graph Draw Types: Price Volume Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-04 20:58:53] |
Hi John, Thank you! |
