Date/Time: Mon, 25 Nov 2024 02:28:04 +0000
Show Order Fills Does Not Recognize Last In First Out Settings.
View Count: 172
[2024-04-04 13:46:16]
User551479 - Posts: 9
Is there a way to change the order that the fill lines are drawn?
I ask this because I trade Last in First Out.
However the Fill Lines are First in First Out.
I have searched and searched to no avail.
If you could point me in the right direction, I would appreciate it!
My Chart Settings>Trade Settings are set to Last in first out.
But When Sierra draws my trades on the chart by posting my entries and exits, and then draws a line connecting those trades, it is still drawing those connecting lines as though I traded it First in First out.
Meaning when I select: Show Order Fills, and it draws a line connecting the open and close of a position, it is still drawing those lines as though I was trading First in First out, but my settings are set to Last in First out.
It is like 'Show Order Fills' is failing to recognize the Last in First out setting when it is enabled.
imageSC Support 4.1.2024.png / V - Attached On 2024-04-04 13:45:27 UTC - Size: 139.71 KB - 59 views
imageSC Support - 2 .png / V - Attached On 2024-04-04 13:45:33 UTC - Size: 125.8 KB - 41 views
