Date/Time: Thu, 19 Sep 2024 16:43:22 +0000
Clearing bid ask volume from DOM
View Count: 1902
[2014-08-13 12:38:53] |
bwalks123 - Posts: 122 |
I just down loaded the most recent version of SC and now I am unable to clear the recent bid ask volume from the DOM? Has this feature been removed?
[2014-08-13 18:22:48] |
This will be solved in the next release coming out later today. You can also right-click on the price scale and Clear Recent Bid/Ask Volume.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-13 18:23:12
[2014-08-15 13:13:40] |
I have updated to SC Version 1174 and see that the "Added a Toolbar button for Clear Recent Bid and Ask Volume" has been added. Where is that button located as I am having trouble locating it on the DOM? Can I use a hotkey for this? Thanks |
[2014-08-15 16:48:33] |
Once you add that ToolBar button to a ToolBar, the ToolBar button is located on the Sierra Chart ToolBar which you will see on the main Sierra Chart window. It is not supported to add a shortcut key for that. We have to see about that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
