Date/Time: Thu, 09 May 2024 21:50:11 +0000
Pulling / Stacking values
View Count: 153
[2024-04-04 08:26:39] |
BenjFlame - Posts: 305 |
Please look at attached image, circled in blue: bid (blue) column and corresponding pulling/stacking column on its left. You can see that on those levels, bid level = exactly pulling stacking level. Also when bid level changes, pulling stacking is changed to exact same quantity. So for example in this case we have a bid level of 4111, and pulling stacking value of 4111. If bid changes to 4000, pulling stacking will be 4000. Is this how this is supposed to be calculated? I would have expected to see -111. |
Screenshot 2024-04-02 102554.png / V - Attached On 2024-04-04 08:26:30 UTC - Size: 41 KB - 41 views |
[2024-04-05 18:16:37] |
Sierra_Chart Engineering - Posts: 14294 |
We have added two options to give the users the ability to control this in the way that you think is appropriate: Global Trade Settings Windows: Limit Maximum Pulling Stacking Value to Current Depth Quantity (Global Settings >> Chart DOM Settings >> Other >> Other Settings) Global Trade Settings Windows: Add Trade Volume to Pulling Stacking Value For Price (Global Settings >> Chart DOM Settings >> Other >> Other Settings) We cannot provide any further help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
