Date/Time: Tue, 14 May 2024 19:25:10 +0000
Trading evaluator - additionnal symbol request
View Count: 103
[2024-04-04 05:24:30] |
archymede - Posts: 19 |
Hello, Is it possible to add FBTS (Short-term BTP - Eurex) to the trading evaluator service ? Thank you |
[2024-04-04 05:27:58] |
Sierra_Chart Engineering - Posts: 14352 |
Yes we will do that.
[2024-04-05 01:07:58] |
This is done. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
