Date/Time: Sun, 24 Nov 2024 04:46:12 +0000
connecting my SC account to AMP
View Count: 374
[2024-04-04 01:00:44] |
User930387 - Posts: 2 |
kindly help to link my account to AMP futures (user id **), thank you. I
Date Time Of Last Edit: 2024-04-04 05:27:22
[2024-04-04 14:28:57] |
The first issue is that you are on a Trial. While on a trial, you can not connect to trading or data services. To do this, you would need to be on one of the "Integrated" packages. Refer to the following: Description of Service Packages and Pricing: Integrated Packages When you are ready to change to a paid package, follow the instructions at the following link: Sierra Chart Purchase and License Information: Instructions In terms of connecting with AMP, we recommend using Teton order routing. Therefore, follow through the instructions here: Sierra Chart Teton Futures Order Routing: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-06-24 00:39:32] |
i wish to sign up your service package trade OSE futures. which package shld i sign up? my broker is AMP & i have signed up their data feed.
[2024-06-24 14:17:16] |
Sierra_Chart Engineering - Posts: 17154 |
You will need Service Package 10 or 11. And for that particular exchange, you would need to use CQG through AMP and CQG will provide the market data. For Sierra Chart pricing, refer to this page: Description of Service Packages and Pricing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-06-24 14:18:23
